Question about Smeg WDI12 Front Load Washer / Dryer
Smeg doesn't dry - Smeg WDI12 Front Load Washer / Dryer
How can I stop my smeg fa561 tripping the electrics
If it's wet from cleaning, just let it dry out. If it is an electrical fault, you will have to test the compnents with a multimeter to find the faulty one.
Dec 21, 2014 | Smeg Refrigerators
Why is the ignition not firing on my smeg gas cooker
It may be dirty. Try cleaning it and let it dry.
Aug 30, 2014 | Smeg Cooktops
Dryer doesn't warm up It's a smeg washer/dryer and doesn't dry the clothes
either the red/ orange wire to the high side limit switch is burnt off !1 of the limit switch itself is fried
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Smeg wdf1 washer dryer not drying clothes. Wash cycle fine but no heat produced when drying- any idea where to find/check the fuses/elements?
Hi, Take the top cover off and click the little red button on the thermostat/overload (small black box). Then try again. Sometimes these trip out as a safety precaution.
Jun 13, 2009 | Smeg WDF16BAX Front Load Washer / Dryer
Smeg dishwasher not orking properly
if water is coming in the drain then you could have a bad check valve. when you open the dw at the end and there was no water it was because you were in the drying cycle and the eement was drying the water as it came in.
Jan 11, 2009 | Smeg CSU2001 Built-in Dishwasher
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Drying operation on WD16BA on smeg dryer
I think all you have to do (that's how I do it anyway), is turn the program knob so that the line is at the beginning of the drying stage (the little 'sun'), having first of course chosen the desired amount of drying time with the knob on the far left...
Hope this helps, good luck...
Oct 16, 2007 | Smeg WD16BA Front Load Washer / Dryer
Smeg WDI12 Front Load Washer / Dryer Logo
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Owen Barnes
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
