Question about Police Watches
Battery change how do i remove remove the cover
How do you remove cover to change battery on kc 2342 watch
watches. Remove the back cover off the watch to reveal the battery. There are a very large range of batteries for watches. Remove the battery with non metallic tweezers or a sharp no metallic point. ...">watches. Remove the back cover off the watch to reveal the battery. There are a very large range of batteries for watches. Remove ...
Mar 10, 2011 | Watches
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
HOW TO CHANGE BATTERY
mcdevito75 here, Depending on your watch itself, Basically you"d remove the back cover, then release any hold down linkages on the battery, then replace the battery, hold down linkages and cover. The BEST BET is to look for a small watch repair shop in your area for this battery replacement as it may take special jewelers screwdrivers to change the battery.
Jul 10, 2010 | Armitron 0501643FA Wrist Watch
Casio Model 2701. Removed the cover, unable to remove battery to replace. How do I take the battery out?
mcdevito75 here, Best Bet, bring your casio to a small watch repair shop in your area, The LCD display can be ruined while replaceing the battery, useing to much pressure, Let the watch shop change the battery.
Jun 26, 2010 | Watches
How do I replace the lithium battery in a Casio Privia PX-100?
mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
Jun 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I change the battery in my Timex Iron Man Triathlon? I removed the 4 screws in the back but cannot remove the cover because of the overlap of the wrist band.
You will need to remove the wrist first before the cover will come out.Else pull the wrist out and allow it to leave a gap and then you can move the cover out.
Dec 19, 2009 | Timex Sports Ironman Triathlon 100-Lap...
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and they can't figure it out.
If you don't have a watch repair kit, a small flathead screwdriver or even a butter knife would work. Set the watch face down on a soft material (pillow/towel). Insert the flat tool in the gap between the back and the watch itself. Apply a bit a of pressure the loosen and remove the back. Remove the rubber gasket covering the battery. Then you will want to remove the clip covering the battery (with the flat tool). Once the clip is removed flip it upside down and let the battery fall out
Nov 29, 2009 | Watches
I want to change the batteries on afossil big tic
i think it pretty much pulls right out, the kid at walmart did it rather quickly.
Jul 03, 2009 | Fossil JR8096 Wrist Watch
How do i change the battery in a timex wr 30 m watch
remove back cover plate- inside you will need a jewlers screw driver- install new batery in reverse. install screw- and snap cover back in place.Make sure battery is new.
Dec 31, 2008 | Timex 27191 Wristwatch
Removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
Watches Logo
12 people viewed this question
Top Police Watches Experts
Jimmy Accardi
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Police Watch Expert? Answer questions, earn points and help others
