Question about Funai Televison & Video
Need a code for F&J FD1920W tv - Funai Televison & Video
I need instructions and codes for a Philmore PM-RC26 iniversal remote.
Check the slot in TV where the HDMI cable is inserted. On your TV remote control (not Philmore) there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. Now take the other remote control i.e. Philmore Universal remote in your hand. Press & release the S (set) button. Immediately enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
Check the Visio TV manual for the Brand name, Model no & TV code if any. Then contact your TV manufacturer or retailer for the TV code to enter & synchronize with your new Philmore Remote Control.
Nov 13, 2016 | Televison & Video
Element 32 in tv
Element 32 in tv - Fixya
www.fixya.com > Forum > Flat Panel Televisions > Element
38 mins ago - element 32 in tv Need a code to run the volume and on off shaw direct sat. - Element Flat Panel Televisions question.
Remote Control Code for Element LCD TV -- & Direct ... - Fixya
www.fixya.com/support/t1101060-remote_control_code_element_lcd_tv
Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
Element 32" 1080p TV (ELDFW322): Unboxing & Setup ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
Jan 20, 2016 | Element Televison & Video
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - Boards.ie
www.boards.ie > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - boards.ie
www.boards.ie > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from www.boards.ie
Dec 10, 2015 | Televison & Video
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
My mother in law just passed away and I inherited back the Sylvania LD320SSX I bought her last year. What is the 5 digit remote code for a Comcast remote? Tried all I could find to no avail.
Comcast uses at least 11 different remote controls. I referred to the manuals listed on their remote control page for instructions on programming the three Comcast-branded remote units:
Comcast Universal Remote (Red OK/Select button)
Sylvania LCD TV codes: 20000, 20035, 20043, 20081, 20593, 21593, 21781
Procedure:
  1. Turn on the TV.
  2. Press the TV button once.
  3. Press and hold the Setup button until the TV button blinks twice, then release Setup.
  4. Enter a five-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  5. Aim the remote control at the TV and press the Power button. If you have the correct code, the TV will turn off. If not, repeat steps 2-6 with a different code.
If none of the codes work, you can try the code search procedure:
  1. Turn on the TV.
  2. Press and hold TV. Press and hold Setup until the TV button light blinks twice, then release Setup.
  3. Press 9-9-1. The TV light will blink twice.
  4. Press and release the digit 1. The TV key will blink twice. Press the Power key.
  5. Aim the remote control at the TV. Press CH+ until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  6. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Universal Remote (Grey OK/Select button)
Sylvania LCD TV codes: 0000, 0035, 0043, 0081, 1781
Procedure:
  1. Turn on the TV.
  4. Enter a four-digit code from the list. If this is done correctly, the TV button will blink twice. If you enter an invalid code, the TV button will produce one long flash and the remote control will exit the program mode.
  1. Turn on the TV.
  4. Aim the remote control at the TV. Slowly Press Power and TV alternately until the TV turns off. You may have to press numerous times until the remote control finds the right code in its library. Stop when the TV turns off.
  5. When the TV turns off, press Setup once to lock in the code set. The TV light will blink twice.
Comcast Digital Transport Adapter (DTA)
Jan 22, 2011 | Sylvania LD320SSX LCD TV
I need the codes for an RCA and Emerson TV
I can help you with your URC-3021 Universal Remote Control issues.
The codes for RCA TV's are: 0047, 1047, 1147, 1247, 1347, 1447, & 1547.
The codes for Emerson TV's are: 0154, 0236, 0463, 0180, 0178, 0171, & 0623.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Apr 19, 2010 | One For All URC-3021 Remote Control
Vivanco tt 716 remote instructions
I have a manual. What part do you need?
To retune the remote to your TV automatically press Power & Mute keys together. Then press TV key. You should have a blue light & a red light. Now press & hold the Power button until the blue light blinks twice & release. The remote will search for your code. If the TV turns off (sorry forgot to mention TV should be on first) quickly press the TV button again to store the code. Then press the Power button to check if the TV turns on again.
If you need the codes. Let me know
Sep 29, 2009 | Televison & Video
Need code for my panasonic tv
try this site the codes are listed
http://www.symdesign.com/codes.for.one.for.all.6.urc-7562.html
Aug 22, 2009 | Panasonic Televison & Video
KAWASAKI LCD TV + DVD / UNIVERSAL REMOTE CODES?
use an LG or Goldstar Code for remote code.
per the manufacture 1/1/09 at 2:03 pm est
Aug 09, 2008 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
