Question about Philips SE56522B Twin 1Line Cordless Phone
Manual what is the scroll on the hand set it keeps flashing
My cordless phone keeps saying searching.i cannot use it. How can I clear it
press menu
go to answering set up
scroll to what is causing the problem ( probably registering other hand sets ) and cancel press menu then end
all in the owners manual
Nov 13, 2017 | Lands Phones
How do i change from remote ttl on my nikon sb800.
Press the Menu button. Scroll to the Custom Setting Menu. Scroll to "e Bracketing/flash". Right arrow and scroll down to "e3 Flash cntrl for built-in flash" and push the center button. You now have access to the TTL, Manual, Repeating flash and Commander modes. Right arrow on CMD and a menu will appear that allows you to set up the built in flash and the external flash groups.
Aug 15, 2013 | Nikon Speedlight SB-800 TTL Flash
PURCHASED USED SIEMANS 8800 HAND SET ,REPLACED BATTERY,AND RESET PIN TO DEFALT 0000, PHONE FLASHING "SEARCHING" .HOW DO I GET THE HAND SET TO SYNK UP TO THE BASE STATION?
You need to register the handset to your base to get the phone to work to do this follow the steps in the manual. If you do not have the manual go to the link below and scroll down to product detail then click on the blue product manual.
Gigaset-Accessory-Cordless/dp/B00005UFDR">http://www.amazon.com/Siemens-8800-Gigaset-Accessory-Cordless/dp/B00005UFDR
Or look below to learn how.
Jun 03, 2011 | Siemens Gigaset 8800 Cordless Expansion...
Flash off mode and want flash on
The Burst setting takes a series of photos, and as such the flash is not usuable as it would not charge fast enough.
I suggest you inititialize the camera -
Turn camera on
Press Menu
Scroll all way across to the right to 'Setup'
Scroll down to the 3rd icon
hit righ hand scroll button, then down to Initialize
Across and up to OK
Hit middle key, then up to OK again and middle key
Camera will turn off, then on at date setting screen
Set the date, and camera will be back to factory seting with the burst off, and flash modes available :)
Jun 13, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Flash not working
the hand sign means that with your current settings, the camera predicts that you will not be able to hold it still long enough, your flash might be in a mode where it does not flash or not very brightly, look in your manual for flash settings, then max the flash out on your camera
Jul 30, 2009 | Canon PowerShot S2 IS Digital Camera
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
Set time an date
To set the Time:
1. PRESS the [Select] button and hold in for 2 seconds. Located in Field 3, the seconds will begin to flash
(Fig. 11).
2. PRESS the [+] button to scroll the seconds upward or
PRESS the [-] button to reset the seconds to zero.
3. At the seconds desired, PRESS the [Select] button to move to the next setting. Located on right of Field 2,
the minutes will begin to flash.
4. PRESS the [+] button to scroll the minutes upward or
PRESS the [-] button to scroll the minutes downward.
14
5. At the minutes desired, PRESS the [Select] button to move to the next setting. Located in the center of
Field 2, the hour will begin to flash.
6. PRESS the [+] button to scroll the hour upward or
PRESS the [-] button to scroll the hour downward.
7. At the hour desired, PRESS the [Select] button to move to the next setting. Located in Field 1, the 24 or 12
hour clock setting will begin to flash.
8. PRESS either the [+] or the [-] button to toggle between the 24hr and 12hr.
Note: If the 12 hour clock is chosen either AM/PM will appear below the hour in Field 2.
9. At the clock setting desired, PRESS the [Select] button to move to the next setting. Located in the center of
Field 2, the year will begin to flash (Fig. 12).
10. PRESS the [+] button to scroll the year upward or
PRESS the [-] button to scroll the year downward.
11. At the year desired, PRESS the [Select] button to move to the next setting. Located in the center of Field 3,
the month represented by a number will begin to flash.
12. PRESS the [+] button to scroll the month upward or
PRESS the [-] button to scroll the month downward.
13. At the month desired, PRESS the [Select] button to move to the next setting. Located to the right of Field 3,
the date will begin to flash.
14. PRESS the [+] button to scroll the date upward or
PRESS the [-] button to scroll the date downward.
Note: Once the user has determined the year, month and day, the Wristop Computer will supply the day of the
week in Field 1. The American month/day -view can not be changed to a day/month -view.
15. At the desired date, PRESS the [Mode] button to accept the changes and return to the main mode.
Note: If the user does not press any button for 1 minute in the setup mode, the display will automatically exit
setup.
Aug 22, 2008 | Suunto Vector Wristwatch
Just bought it... 'My colours' option is not accessible.
Those options are only available when the camera is in P, Tv, Av, or Manual modes. When in the Auto mode or one of the scene modes, the camera sets these options. (See pages 206 - 209 in the manual.)
Jul 23, 2008 | Canon PowerShot A720 IS Digital Camera
Warning symbol
Problem with Nikon 4600, system error 1 0 after a memory card used in a Nokia set , any solution
Mar 20, 2008 | Nikon Coolpix 4600 Digital Camera
Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Oct 18, 2007 | Siemens Gigaset 8825 Cordless Phone
Philips SE56522B Twin 1Line Cordless Phone Logo
13 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
