DELL PRECISION T7400 Blue screen apears multiprocerssor configuration not supported
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Since the Precision T7400 has 2 CPU sockets, then assuming there are no "beep code errors" and all the diagnostic lights go off and the power light is green then you probably need to go into the BIOS (press "F2" when the Dell logo comes on during start up) and find the setting that enables multiprocessor support and ensure that multiprocessor support is enabled. If it isn't change the setting so that it is, save the changes and reboot. If it is then it sounds as if one of the CPUs is not functioning properly. Please note that for multiple processors to work, they must be exactly the same.
Posted on Feb 16, 2014
3 Suggested Answers
kevinkrause
SOURCE: Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Posted on Feb 25, 2009
the_fire
  • 432 Answers
SOURCE: Dell Precision Workstation 670
Try different memory modules ( RAM ) and see if it is just the RAM.
Also take anything else out you dont need - including dedicated graphics card assuming it has onboard graphics card ( if so then enable the onboard graphics card before taking out the dedicated one )
If its still the same then yes it is the motherboard in which case you need the motherboard replacing.
If you did the diagnostics that they walk you through and they still tell you its the motherboard then it will be the motherboard as there diagnostic software is accurate.
Posted on May 06, 2009
DELL PRECISION T7400 SECOND CPU NOT SUPPORTED
IF YOU HAVE A PC-Os YOU NEED A SERVER Os.
A PC-LICENSE ONLY GOOD FOR ONE CPU,YOU NEED A
SERVER-Os.I SUGGEST YOU READ SAME ON THE NET ABOUT
IT.
Feb 14, 2014 | Computers & Internet
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
Windows XP fails to shut down properly an hangs with a blank blue screen.
sometimes that can be cured with a disk optimizer routine
try this one and see how it works for you
May 29, 2012 | Dell Precision Workstation T7400 - Energy...
Where to locate Dell t7400 serial no.
It should be in the back or on the side panel of your machine. Go here and see if you can paste it in Click Here input your model information and it will gather and show you where these things are located. John
Apr 19, 2012 | Dell Precision Workstation T7400 PC...
Can a recovery set up H/drive from T 5500 be run on a t7400. would like to just change them over instaed of all data transfer. cheers
you can try it but due to the large difference in Chipsets and system configurations it will most likely blue screen on boot if it boots at all
I would expect you can migrate data but the windows and driver installs will need to be done from scratch
Jun 03, 2011 | Dell Precision T5400/ T5500/ T7400/ T7500...
Nvmini.sys file error screen went blue showing error like non paged sysytem fault.
I sounds like nvmini.sys is a virus or rootkit from what I have just read.
It seems like it is quite tricky to remove. Try searching google for nvmini.sys removal.
If you are not particularly technical, you may be better off paying someone to clean it off for you.
Hope this helps.
May 07, 2011 | Dell Precision Workstation T7400 - Energy...
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Purchase of workstaion/server for three diemnsion simulation
Hey sorry for the late reply
you dont need much surprisingly
1 AM2(X2) DUEL CORE DUEL PROCESSOR MAIN BOARD >> i suggest msi
2 AM2 AMD PROCESSORS abt 4.0 GHZ each
4 GB MEMORY
2 500 GB HARDDRIVE (SATA)
1 DVD BURNER
an alien case with a 650watt (or more) power supply
enjoy
Oct 26, 2007 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
