Question about Philips 42PF7220A 42 in. Plasma Television
TV will work for about 4 minutes, then it will turn off. The green light (power on light) goes off. Then a red light flashes on 5 times in a row, then pauses and repeats. While this is going on, I hear clicking sounds inside the TV like its turning itself on and off.
Philips tech support said it had to do with a power source problem but to be sure, take it to a Philips authorized dealer. I called 2 and they said I was looking at $950 to fix it.
I took out the fuses and tested them, they were all good. Is there a part I can replace?
  • 1 more comment
  • dentistheman Jul 08, 2008
    same problem. green light, but no video or sound, then a repeating clicking sound, then red blinking red light. I tried to unplug it over night but this didn't help.
  • qxq831 Feb 11, 2009
    same problem. green light just second times, screen is black, then have a clicking sound(it's a normal sound), then red blinking red light. I tried to unplug it over night but didn't help,I check the central power board all fuse it's ok,I think the problum still is power board.if you don't have diagram it's difficult.
  • Anonymous Mar 30, 2009
    I have the exact same problem
I had a Similar problem where I would turn the tv on and the green light would come on and then the red would follow and blink 7 times. I tried unplugging it and then then replugging it back and it would still do the same. What I did last night was that I unplugged it and then replugged it back, when I saw the green light, I would unplug it again, till the light went out and replugged it, I did that 3 times in a row, and waiting and it came back on. Hope that works. I still don't know what caused the problem to begin with..
Posted on Apr 08, 2009
    Sergeant:
    Champion:
  • 223 Answers
If you know how to circuit test or at least check components for tolerances then check your power supply board starting with all the diodes and capacitors you can find. I think that noise you can hear is a faulty capacitor. Please remeber to discharge all capacitors before you work on anything because at worse it could end up seriously injuring you at best it WILL fry other parts of your tv. Good luck.
Posted on Oct 03, 2008
I have a philips 42" plasma t.v.model
hello sir Dave!!!
welcome to fixya..
Lets find out if that problem is worth to repair or not..I need some info regarding your TV such as how many flash of LED lights in front?..It will help to diagnose where the fault came from..
Please reply to this tread to post the info I need..
Thanks for using fixya..
regards,
Chester
Feb 24, 2012 | Philips Magnavox 42MF521D/37 Television
Our screen our Philips 42pf7220a/31 just went blank,(black) the power light is green and the sound works. Any ideas what's wrong
1st take alook at your wires to make sure that they are plug in if this is ok then take a look at the fans in the rear of the TV make sure that they are working.
Thanks
Todd
Feb 17, 2010 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
RED LIGHT BLINKS SEVEN TIMES
The most likely problem are two failed capacitors on the main board in the center of the TV The failed parts are easy to identify as the top of the cap will no longer be flat but will have bulged up. DO NOT attempt to remove the back of the TV unless you know what you are doing.
soldering on a circuit board will be required to fix this problem.
Aug 10, 2009 | Philips 42PF7220A 42 in. Plasma Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Aug 03, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
385 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
