Question about Konica Minolta 2 Pack Bizhub C-250 C-250p C-252 Tn-210m Magenta Toner
When i power on the machine it give the error C-D307
  • Konica Minolta Master
  • 6,161 Answers
Abnormality is detected by the abnormal check of each NVRAM Data. Need to have tech come out try to re flash the firmware on the machine worse case you need a new control board and the Non Volametile memory is gone which house certain counter info and boot info for the copier not available on the internet only secure site at Konica Minolta they want to protect their software
Posted on Jan 18, 2016
Pioneer vsx d307 to self powered sub?
If your pioneer receiver has a separate subwoofer output, connect it to your sub.
Dec 30, 2016 | Pioneer Audio Players & Recorders
Pioneer VSX-D307 has no sound from right front speaker.
Did you connect a known good speaker to the amplifier's right front output connections? Make sure you also have known good wires for the front right as well. Make sure balance control is set to the middle and not just to the left.
Aug 22, 2016 | Pioneer VSX-D307 Receiver
Sony LBt-d307 user manual
I could find the HST-D307. Just with Google and it was the first hit.
Should be the same manual as for the LBT, but I can't see that.
http://diagramas.diagramasde.com/audio/HST-D307%20Service.pdf
Jun 26, 2014 | Sony Ps-lx49 / Ps-lx49p Stereo Turntable...
Errore code c-d307
Sounds like a bad NVRAM board. When it goes bad it resets everything.
Nov 27, 2013 | Konica Minolta bizhub C351 All-In-One...
Pioneer VSX-40 won't power on
check the fuse or ic regulator
Feb 26, 2013 | Pioneer VSX-D307 Receiver
Overloads with volume a third od the way up,i have 2 12 inch cerwin vegas hooked to it
fan_of_tony,
There is not much info in your question to properly answer it but here are a few things.
1) The VSX-D307 is a home receiver that is rated for no less than a 4 ohm load. If you have two 12" 4 ohm CV subs on the same channel and they are in parallel, that would create a 1.7 ohm load which would easily cause the problem.
2) If you have one on each channel connected along with speakers that are for you mids and highs, the way they are connected could be reducing the resistance load the amp will see which would easily cause the problem.
3) If you have one on each channel and no other speakers the problem would be simply that your speakers can use more power than the amp can produce. Thus you are able to raise the volume of the amp passed it's maximum output which would cause the amp to clip and the amp will go into overload protection.
4) Your receiver has an 8 ohm rated amp. Which means it can run at 4 ohms but the amp will produce more power at lower volumes on the knob setting and will max out at lower levels than if you were using a 8 ohm speakers.
In short, CV's can use a lot of power and your receiver, regardless of advertised power levels, cannot give the speakers what you are looking for in sound levels. Buy a larger dedicated amp for the CV's as the clipping from your Pioneer receiver is doing damage to your CV's. Your speaker's can hear the clipping before your ears can so damage will start to occur before your ears can hear the clipping.
-Chris
Jan 20, 2010 | Pioneer VSX-D307 Receiver
Samsung sgh-d307 stopped working
u need to reinstall ur phone's operating system. better u take it to any technician or samsung's service centre.
Feb 20, 2008 | Samsung SGH-D307 Cellular Phone
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
Konica Minolta 2 Pack Bizhub C-250 C-250p C-252 Tn-210m Magenta Toner Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
