Question about Dishwashers
Kleenmaid dishwasher What does a D13 warning light mean and how do I turn it off!
My Kleenmaid is displaying a flashing D13 message, but is still working. How do I turn it off?
SOURCE: Kleenmaid DW3 dishwasher not running.
Hello, this isn't a fix, but if you can't get the dishwasher fixed, I am interested in purchasing the cutlery baskets off you, if they are still in reasonable condition. Mine has plenty of breaks in the base and the handles poke through, which affects the lower spray arm rotation. Please reply through another post if you're selling. Thanks.
Posted on Jan 08, 2008
  • 180 Answers
SOURCE: kleenmaid dishwasher wont run, all lights on at same time
Check the door switch.
Posted on Oct 25, 2009
SOURCE: how to replace a kleenmaid brandt dishwasher door handle
Go to www.espares.co.uk
Look for "Dishwasher Door Handle Opening Pedal" - Genuine spare part for select Blomberg and Hygena dishwashers.
This is the part you need for a Kleenmaid/Brandt DW3 dishwasher.
Posted on Feb 04, 2010
SOURCE: my Kleenmaid dishwasher is stopping
This is a Pump Filling Fault.
As described in your manual to download below. Could be the pump, the controller, the door sensor, a float switch stuck.
kleenmaid-appliances.com/DW/KM_DW/DW37i_B3097_C_EN.pdf
Below is a DIY self help site to assist you to isolate and hopefully repair your issue. If you do wish to DIY, then you MUST obtain a service manual for your exact make and model, simply Google for one. Follow troubleshooting steps inside to find the problem.
Sometime under the inspection hatch, you may find a maintenance manual, in a plastic bag, not always though.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
If you don't wish to DIY, then please call a professional, ask for a "Quote" and go from there.
Posted on Aug 30, 2010
  • 10 Answers
SOURCE: Have Kleenmaid "Super silent system"
Dishwasher Doesn't Fill
1) First make sure the water is turned on. Check the hot-water supply stop valve, normally located under the sink. Open it all the way by turning it counterclockwise. If there is no reason this would have been turned off since the last time the dishwasher worked, go on to the next step.
2) Turn off the power to the dishwasher.
3) When the dishwasher is cool, look for the float inside the dishwasher; this is usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring-loaded).
Lift out the float mechanism, and clean around the float tube. Many floats must be disconnected from below; to do this you'll have to remove the lower access panel. Rinse off the float, replace it in the tube, and make sure it moves up and down freely.
4) If you're experienced with minor repair work, shut off the hot-water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel; disassemble the valve to reveal the screen; clean debris from the screen; and reassemble. If the screen doesn't appear to be blocked, call a repairperson (he or she will probably need to replace the water intake valve).
5) If none of this helps, call a repairperson. Any of several parts-including the water inlet valve, pressure switch, and the timer or selector switch-may be faulty.
Posted on Apr 09, 2011
My kleenmaid ked600 condenser dryer is giving me a F4 error code. And not heating. Could it be the thermostat? Where can I locate the meaning of the error codes ?
In case of F0, F1, F2, F3, F4 failures,
contact your service technician without
hesitation.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/DR/KM_DR/KED600.pdf
and then I found this
"F4? Too much lint in the lint filter, front housing, or in the condenser Clean lint from lint filter and/or condenser I would just contact them.
http://www.kleenmaid-appliances.com.au/support/contact-us/
Mar 04, 2016 | Dryers
I need opperating instructions for my kleenmaid dishwasher dw20x
http://dish-washer.download-servicemanual.com/kleenmaid-dw20w-dw20x-dishwasher-instruction-manual.htm
Nov 22, 2012 | Washing Machines
Kleenmaid G10-FF6 Manual
Hi Andrew,
I tried looking for the manual but couldn't find it. Here's what I found:_____________________Urgent Information for Kleenmaid CustomersKLEENMAID LIQUIDATION NOTICEThe Kleenmaid Group was placed into liquidation in May 2009.
Kleenmaid Customer Solutions, the former Kleenmaid appliance service business was acquired by Aussie Whitegoods Rescue. For service, spare parts or sales on replacement product please phone or email our contact centre.
For further information relating to the liquidation of the Kleenmaid Group, please visit the Deloitte website www.deloitte.com.au or email kleenmaid@deloitte.com.au
For Service, Sales & Spare Parts you may call Aussie Whitegoods Rescue at Phone # 1300 652 100. Trading Hours 8.30am - 5.30pm Mon - Fri EST
They might be able to help you with the manual for your oven.
I hope this helps.
Dec 05, 2011 | Ovens
Do you have a manual for the Kleenmaid DW20W dishwasher?
pushed on button. lights are on . Wont let me select settings . has 3hr delay light up . salt light on. pushed start button and nothing happens.
Dec 27, 2010 | Dishwashers
My Kleenmaid dishwasher is stopping during the cycle and displaying fault D14, what does this mean
Aug 30, 2010 | Dishwashers
How to replace a kleenmaid brandt dishwasher door handle
Jan 22, 2010 | Dishwashers
Need part for electrical mother board
You can now order Kleenmaid service parts at www.edis.com.au. Login to their online shop with the user name "retail"and password as given on the login page. Search for the parts you are looking for.
I successfully purchased and received spare parts for a Kleenmaid dishwasher this way.
Apr 29, 2009 | Washing Machines
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
Owen Barnes
