Question about M-Audio M Audio KeyStudio 49i Controller Keyboard and Software Pack
There is no power when i connect my m - audio keyboard 49i to laptop
2-in, 2-out audio interface 16-bit, 44.1kHz (CD-quality) XLR microphone, 1/4" instrument and RCA inputs 1/4" jacks for stereo line output dual front-mounted headphone jacks hardware direct monitoring Pro Tools* compatible
CRTN
  • 716 Answers
SOURCE: I cannot get it to work with garageband - won't take any sound in
Is It A Condenser Mic? If So You'll Need Phantom Power
Posted on Jan 05, 2009
SOURCE: My microphone CL7 Studio Condenser Samson does not work.
your microfone needs a phantom power to work,so your fast track dont have the necessary energy to make you microfone work, so you need to conect you microfone on a pre amp then your fast track, this is gonna make your microfone work like it shold.
Posted on Jan 19, 2009
SOURCE: M-Audio KeyStudio is connected using the USB cable
Soltion is to download the software for Micro USB from M-Audio website and connect the USB of the Micro USB to your computer with headphones and mic connected to it and connect the USB cable from the M-Audio KeyStudio keyboard to the computer and the Pro Tools M-Powered Essential software will work.
Posted on Feb 07, 2010
SOURCE: Only the microphone input works for recording but
micro panel control is in not connecting
Posted on Feb 13, 2011
SOURCE: when i first dounloaded my
in icon fast track usb the micro control panelsay not connected
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
I just bought the GXL2200 CAD microphone without the cabels,(thought they would've came with), what kind of cable do i need?
As with most microphones, these mics use XLR cables. You can get them online or in a music store in many different lengths. What you need is XLR male to XLR female, though most of the consumer-level stores will probably just call them "mic cables." Note that the thing you're plugging into will need to have an XLR input, and will need to provide phantom power in order for that mic to work.
Nov 09, 2013 | CAD Microphones GXL2200 Professional...
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
Son wants to buy CAD GXL2200sp studio microphone package and wants to plug into laptop.Will that work?
for purposes of recording quality, I would recomend getting and external sound card. M-audio make a good range. You would need to have a +48v phantom power supply for this unit to work. The sound card you buy should have this. A Pc or laptop won't
Jan 16, 2011 | CAD Microphones GXL2200 Professional...
Would like to use with a mac computer but it does not have a USB cable. Please let me know if it could be done. Thanks.
This is because this microphone has an XLR audio connector for output. YOU CAN'T USE THIS CONNECTOR FOR THE USB PORT since the XLR is an audio type connector while USB is a data type connector. You might use a cable with XLR female at one end and 3.5mm jack like this one with mono jack at the end (not stereo as the amazon's link) and connect this cable at the microphone and at the sound card of your computer. The quality with this solution won't be very good, it depends on your audio card. A better solution is to use XLR-to-USB-Signal-Adapter/dp/B001PPXFAG/ref=sr_1_16?ie=UTF8&qid=1290885531&sr=8-16">this adaptor or equivalent in order to connect the mic on the adapter and the adapter with a USB cable at your computer. It's a better but more expensive solution.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 27, 2010 | Samson R21S Microphone
I have a mic Behringer C1u and would use it with an M-Audio fast track usb interface. How can I do it?
You will need to turn on the phantom power which will be a switch labled eithe PHANTOM or +48V to use the condenser mic. YOu MUST use an XLR to XLR cable.
Sep 10, 2010 | Behringer C1U Microphone
How to connect XLR plug to Combi-Connector socket
You need a D.I. (direct interface) box. Most have XLR to 1/4" . You have to go from the 1/4" to your size jack. Remember your taking a low impedence device to a high impedence input thats why you need a D.I. you just can't make a cable to do that. Also I think you mean a 3.5mm jack.
Apr 11, 2009 | Audio Players & Recorders
Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Nov 05, 2007 | Canon GL2 Mini DV Digital Camcorder
M-Audio M Audio KeyStudio 49i Controller Keyboard and Software Pack Logo
754 people viewed this question
Top M-Audio Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a M-Audio Science and Laboratory Expert? Answer questions, earn points and help others
