Question about Sentry Fireproof Safe
Sentry stuck solenoid - Sentry Fireproof Safe
How do I open sentry H4100 file safe
Proceed to watch this video link that I added. It will guide you on how to open your stuck file safe. HowTo Open Stuck Sentry Safe H4100 Others
Oct 19, 2014 | Sentry Safe Products Sentry Safe H4100...
How to open sentry safe s0130 after being moved
Spray the key hole with graphite. Should loosen up whatever is stuck.
Jul 20, 2014 | Sentry Fireproof Safe
My Sentry 3150 safe is closed and locked and the lock/dial is stuck. The dial only turns between 20 and 25.
If their "Frequently Asked Questions" do not address this problem, I would probably call them and ask for clues... https://www.sentrysafe.com/ContactUs/Call_Or_Email_Us
Here's what one guy did to open a Sentry safe.
Jun 15, 2014 | Sentry Fireproof Safe
Won open my sentry safe f3300 is stuck
The best way to break the rubber water proof seal is to push down on the left rear corner. That will pop open the front right corner need more help you can get my phone number here
Apr 03, 2013 | Sentry Fire Safe Waterproof Security File...
Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
Dead battery and safe wont open
battery cover can be removed from outside. replace batteries and try again but if you remove batteries more than 1 or 2 times in a row, safe will revert back to a factory setting. That number should have been on your instruction sheet when bought. Good luck though, I bought a Sentry A3821 and it's only 5 years old and won't open.. After help from sentry I was told solenoid is bad and no longer made. So I now have a piece of junk bolted to my floor
Oct 27, 2010 | Sentry Fireproof Safe
Sentry Graphing Calculator ca753
to clear the BASE-N display off the CA756 Sentry graphing calculator press [mode] and [+]
Jun 08, 2008 | Sentry CA 756 Calculator
New sentry csw3813 stuck open
do you have the manual i have the same problem but close and the manual is inside the safe is the original keycode but dont remember it
May 18, 2008 | Sentry Fireproof Safe
Remove the screw from the backside of the door.
Feb 25, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
59 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
