Question about Dryers
My EDE05 drier has stopped working. Lights are still on, but no rotation.
My EDE05 drier has stopped working. Lights are still on, but when you try to start it there is a humming sound - no heat, and no movement. I had a duvet in it at the time, and, and there was a burning smell coming from the dryer when I found it stopped. The drier has had a lot of use this week with me restarting it immediately after it stops, as the sensor isn't making large items dry on the first round. This dryer is <4yrs old. Do you think it's a belt? or is the engine wrecked? thanks!
    Top Expert:
  • Dryers Master
  • 40,402 Answers
A likely suspect is the belt which may have broken. If it broke while the duvet was being dried, it could have gotten roasted in the stationary drum.
Posted on May 26, 2017
  • 131 Answers
SOURCE: maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Posted on Mar 31, 2008
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
  • 8220 Answers
SOURCE: Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Posted on Dec 22, 2008
  • 979 Answers
SOURCE: Brand new Dryer starts then stops after 15 seconds
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
Posted on Feb 11, 2009
  • 103 Answers
SOURCE: samsung front load dryer had a burning smell-it
ck recalls on this issue.
there may be one.
under warranty??
do not buy samsung they are notorious for having problems.
sounds like the heating element and relay may have went out.
however if it does not start up at all it could be the motor itself.
Posted on May 14, 2009
Miele WT945 drier removal
Hi dear.
It is very complicated work. I can suggest you should not involve doing that but if you know what you are doing try that out. See if it helps.
Common problem: Stuck drying air fan shaft.
1- Unplug machine from power. Remove top cover.
2- RHS at the back,on outer drum horizontally mounted motor,drives a belt.
3- Try to rotate motor shaft (impeller) by hand, see if it's hard to rotate. Try to make it free to rotate.
3- If you have a capacitance meter, check value of capacitor should be in range of 2.5 uF if not replace capacitor.
Beyond that you need to get tech. to assist your machine. I hope that helps so far. Thanks.
Feb 25, 2016 | Miele WT945 Front Load Washer / Dryer
When it reverses, why is there a loud squak/thud noise?
you need a repairman driers only go one direction normally
Aug 28, 2015 | Dryers
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
Amana LE7153WM drier will not start... makes a low humming sound when you push in the select dial to start the drier
Hi John, W/D here.
Most likely scenario: squealing was either a belt or a bearing. Failure to run is probably a broken belt. Gain access to the back of the drier, with the power disconnected. Open the back and check the belt. If broken, replace it, and then rotate the drier by hand, listening for additional squeals and squeaks. If no other issues are noted, replace the back cover, plug it back in and try it out.
Best regards, --W/D--
Nov 09, 2011 | Dryers
Our Hotpoint Aquarius dishwasher initially had the Eco & Prewash lights flashing & standing water inside. We then turned it on in the hope that the standing water would drain, which it did. It then...
Is it a dishwasher a washing machine or a drier? Washing machines don't have rotating arms and you said "I've managed to get the drier to drain"
I will assume it is a dishwasher in which case it sounds like your pump has failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Drier was working O.k . Timmer Stop working And so did the Heating. Does the Timmer control Temperature aswell.?
Yes, if the timer mech is damaged and, it will not rotate, this is cause the heating cycle to become inoperable. the time is responsible for initiating the heating command and the thermostat helps with the temp regulations. replacing the timer will restore the normal functions of your dryer.
Jun 18, 2009 | Whirlpool LER5636P Electric Dryer
Gas drier kenmore heavy duty
The motor is bad or the drum is locked up can you turn the drum by hand ?
Dec 13, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
22 people viewed this question
Top Dryers Experts
