Question about Canon PIXMA MP130 All-In-One InkJet Printer
I have blank lines through my printouts
When I print a document there are horizontal lines thru the printout, at first I thought there was a space being added but it seems that information is missing    lines of text are showing only the top or bottom half ot the line the rest being blank I have changed the ink cartriges but the problem remains. I have also run the head cleaning ang head reconditioning routines with no change
  • dadio55 Jan 07, 2008
    I have tried all of the cleaning steps, I have also removed the print head and soaked the jets in alcohol with no change; with one exception.
    I printed an index sheet using Canons Zoom browser which came out perfectly but the next print job (4x6 photo print) returned to the previous problem. I then tried reloading printer drivers but the problem remains
    this appears to be missing data more than clogged jets, note the even spacing of the lines and lack of distortion of the photo, text shows up in the same way
  • Anonymous Mar 22, 2014
    When printing a copy of an A4 page of text the last 3 or 4 lines at the bottom of the page do not appear on the printout
  • 833 Answers
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Posted on Jan 05, 2008
1. Use isopropanol alcohol to swab the print head 2. Clean the rest of the printer of dust and debris by vacuuming or wiping 3. Print a test page 4. If the test page still has lines missing repeat steps 1 - 3
Posted on Aug 17, 2008
Black lines
Replace the toner cartridge :-)
Apr 05, 2014 | HP LaserJet 1020 Printer
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
Nov 09, 2017 | HP Photosmart 2710 All-In-One InkJet...
When i am giving a single page printout it will printout another copy of blankpage
Please open the document, There is probably a second page added to your word document.
Open the file, go to page 2, press backspace.
When you select print option, now check how many pages its showing for printout.
If its showing one page then your file is perfect now.
Nov 03, 2009 | HP Inkjet 1200dn Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
it could be that the lines on the spreadsheet arent bolded correctly or the spacing at the end of the document needs to be shortened. try to delete one space so that that line is brought up a line.
May 27, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Black lines interferring with printouts
Not really sure what you mean by lines on your documents, but you could have excessive ink spilled on your printer rollers.or the page bar,,this can usually be remedies by taking the printer apart and carefully cleaning all of the surfaces the paper run against.
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Magenta horizontal banding on all color printout
I suggest that if your machine is under warranty you call out HP, as I have heard that they don't support these machines with parts therefore you will get a new machine.
Good Luck
Dec 09, 2008 | HP Photosmart 3310 Printer
Copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Dec 20, 2007 | Office Equipment & Supplies
I need to know if this is a sudden occurence or has it happened before. Is cartridge new or refilled or older, and did it print right until now. Also need to know if you have made any recent system changes and if you run anti virus and spyware.
Mar 12, 2007 | Lexmark X1195 All-In-One Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
2,407 people viewed this question
old marine
old marine
