Question about Dishwashers
White Knight DW1260WA not draining - Dishwashers
How do i wirea white knight tumbler dryer heater
take the back off look for heater and follow wire make up two wires the same colour fit a spade clip to both ends and replace
Mar 08, 2015 | White Knight Press 44AW White Tumble Dryer
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Code troubleshooting
White knight dishwasher flashing red light and. Won't. Empty .
could be something in drain pump need to bail the water out of dishwasher best way is a small scoop take filter out and you can get to the lowest point of sump. Take water out and use sponge for the dregs . Un plug appliance and turn water off remove inlet hose and waste pipe. Lay the appliance on its back and remove the base of the appliance you will then see the drain pump remove 3 screw and gently remove pump head and remove object but watch finger if it's a shard of glass .
Jul 15, 2014 | White Knight Press DW1260WA 600 mm White...
Has this dishwasher had any recall notices or advisories
To my knowledge only bosch dishwashers and hotpoint and a few hoover dishwasher had recall notices on them
Jun 06, 2014 | White Knight Press DW1260WA 600 mm White...
I need a user manual for my White Knight Washer Drier
Try this PDF this seems to be for the 77AW by White Knight!
Jun 24, 2012 | Washing Machines
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
White Knight 44AW electrics problem
You may have a short in the system, make sure your breaker is rated high enough to support the dryer
Oct 06, 2009 | Abbaka White Knight 44AW Electric Dryer
Oil
Drain it and put in fresh check for motorhead kracks white means water in engine.,,
Nov 10, 2008 | 2000 Neval Sovjet Knight
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
