Question about iPhone Apps
Email messages will not move to trashcan on iPad
WWhy, having moved been moved from BT Yahoo to BT Mail, do my email messages when down loaded to Windows mail, no longer move to the Bt Trash Box, they now just dissappear from BT Server?
Is the mail bix you are using it is over exchange or webmail please clarify and if you have upgraded to yahoowebmail then check it in basic html mode.
Oct 02, 2014 | Computers & Internet
How do I empty trash email on iPad 4
How to delete or move ALL emails at once in non-jail broken ipad or iphone
It took me weeks of research to figure out finally how to decode this yet another secretive secret of apple. There is a perfect way of deleting ALL emails at once without jailbreaking your iphone or ipad...and here it is:
>> Open Inbox >> Edit >> Mark All >> Mark As Read [Added May 21, 2014 by Adrian; this extra step makes the difference between success & failure for some.]
>> Open Inbox >> Edit >> Check/select the top message; it will highlight the move button.
>> Press and hold the move button and uncheck the message that you had checked earlier.
>> Lift all your fingers off from the ipad screen and leave it alone. Wait until all your messages pile up on the right hand portion of the screen (in ipad); iphone will give you the actual number of emails it has selected for the action. Now they are just waiting for your command to be moved ALL at once.
>> Choose trash to delete all of them or any other folder where u want to move them, like one piece. Remember this will replicate your action on the server so you will ACTUALLY move them or delete them on the server and not just the ipad.
Once you have moved all messages to the trash you can either leave them there for the scheduled cleaning or empty it right away by doing this: go to trash folder and touch Edit. The Delete All button shows up at the bottom of the screen. Hit it! You're done!
If you do not see the effects of your actions on the server make sure you have enabled your email accounts for such actions.
Tips:
1. Please give enough time (could take up to several minutes depending the number of emails to be moved) for the emails to be selected for the move. Your screen will become unresponsive while all emails are being packaged. Once emails are ready, in ipad, you will see them zoomed out on the right hand side of the screen, and in iphone you will see the message showing you the actual number of messages that have been selected.
2. Avoid purging very large number of emails, the mail app might freeze or crash. If your inbox has thousands of emails change your sync settings in mail settings to fill lesser number of emails in your inbox.
3. [Added Jul 20, 2014 by Adrian] Many people have reported needing to repeat the above procedure several times before it succeeds. (I too have found this to be necessary a few times on my iPhone but not on my iPad-go figure.) So my final tip is to repeat the procedure 3-4 times if the mail doesn't disappear the first time. In my experience, if your messages disappear momentarily and then reappear, repeating the procedure will eventually make them stay deleted for good.
4. [Added Sep 18, 2014 by Adrian] If you are using IOS 8, there is a setting that may reduce emails piling up on your device! Go to Settings -> Messages and select Keep Messages under the Message History header. You'll be able to choose to keep your messages for 30 Days, 1 Year, or Forever.
Sep 29, 2014 | Apple iPad Tablets & eReaders
When I go to email on my Ipad my Inbox is overflowing with old emails that I had previously deleted on my desktop, how do I get rid of them quickly and stop others coming in
Settings/Mail, Contacts, Calendars then tap the account you're having trouble with.
Assuming you're using an IMAP account, tap the account user ID on the first line. Scroll to the bottom and tap Advanced.
Tap Deleted Mailbox. In the ON THE SERVER section, tap Trash (making the Trash mailbox on the server your "Trash" location). Back up to Advanced and make sure MOVE DISCARDED MESSAGES INTO: is set to Deleted Mailbox.
You may want to do the same thing for your Sent Mailbox (using Sent on the server for sent messages - so they're retrievable from your desktop).
This fix may result in all the old deleted messages on the iPad being moved to the server and then showing up again in your deleted messages on your desktop. The Mail app will eventually delete them as it does any deleted messages according to its settings.
Aug 30, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Cannot delete an advertisment in my email, it appears with green background
That's how Yahoo! makes money, from advertisers, since we users don't pay for its services.
Aug 23, 2014 | Yahoo Mail
How delete incoming message on iPad
Open the email. Click on the file folder icon top right. Menu will appear on left. Tap on trash. This will move to to the trash.
Jul 17, 2014 | Apple iPad 32 GB WiFi Tablet PC
Deleting youtube history from my ipad
in the app, click on the three lines at the top left, then history, then the trashcan icon. This will clear all within the youtube app.
Jul 16, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I dont want to create a folder I want to delete it!!!
Ipad---Hold finger on app that you want to delete when screen changes and the icons start shaking hit the x and it will delete it.
Android-- select the app hold your finger on the app, screen should change or you will see a trashcan or else thew letter x with delete, slide the app to either the trashcan or the x, you will be asked are you sure you want to uninstall this app. Make your selection.
Mar 17, 2014 | Tablets & eReaders
How to Delete all email on iPad 2, iOS7
Want to delete more than a single email message? You can easily delete multiple email messages from the iPad by using the Mail's edit feature. The button on the top right side of the inbox is the edit button. Touching this button will put your inbox into edit mode.
Once your inbox is in edit mode, you can select multiple messages by touching each message you want to delete. You then have the option to either delete them by pressing the delete button at the bottom of the screen or moving them to a specific folder by touching the move button.
Oct 12, 2013 | Computers & Internet
I am using ipad 2 and unable to send email....
This is what you are to do if the IPad 2 can't send email but can receive mails.
1. Turn on all SMTP servers
On the iPad 2 click on Settings then Mail, Calendars, Contacts and under Accounts select the account your are trying to fix
Select Account
Scroll down to Outgoing Servers and tap on SMTP
SMTP
Click on all the Other SMTP Servers to switch them on
Other SMTP Servers
2. Set up your email account on the IPad 2 itself rather than syncing them from your computer
Open iTunes on your computer, connect your IPad 2 with the USB cable, and then select IPad 2 in the Devices section
Select the Info tab
Unselect the check box next to Sync Mail Accounts
Click Apply
When the IPad 2 has finished its sync, disconnect it from the computer
On the IPad 2 click on Settings then Mail, Calendars, Contacts
Click on Add Account and then follow the onscreen Wizard. When you enter your email address the IPad 2 will try to get the settings automatically. If that doesn't work you will have to get the set-up details from your email provider
Check your email again to see if the issue is resolved
3. Restart your IPad 2
Press and hold down the Sleep/wake button on the top of the IPad 2 until the red slider appears
Move the slider to switch the IPad 2 off
Press and hold the Sleep/wake button to restart the IPad 2
Sep 09, 2011 | Yahoo Mail
iPhone Apps Logo
109 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
