Question about Panasonic NN-SD688 Microwave Oven
Is there a reset button on microwaves? My Panasonic microwave just quit. It isn't that old.
Panasonic 1300w NN-SD6886 Stopped working all at once. I checked the plug and that's working so I was wanting to see if I could find a reset button on the microwave. Most electrical things have one, but I don't know where it is on a microwave. Thanks
OVEN NOT BROKEN JUST WANT A MANUAL TO MAKE THIS OVEN WORK CORRECTLY
Elizabeth, Google search your Microwave make and model# manual. This is how I would do it.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 01, 2016 | Toaster Ovens
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
Reset button on microwave?
Chances are you've blown the fuse under the outer shell.
There is no reset.
Feb 15, 2014 | Panasonic NN-SD688 Microwave Oven
Half oven is working microwave oven is not working
You can buy it from Sears for $52.00 or you can call 1-800-330-9707 and they will mail you one free.
Dec 31, 2013 | Apollo Half Time Convection - Microwave...
Bravetti euro pro microwave convection oven stops working
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#7#ixzz2hPnOVle4
Oct 11, 2013 | Toaster Ovens
It wont turn on model T0131SWD!!!!!!!
follow this charter troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gUR97IFo
Oct 01, 2013 | Black & Decker Toaster Ovens
3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
Krups FBC2 Convection Toaster Oven Simply no power at all.
Having a toaster oven and a coffee maker on the same circuit is asking the breaker to trip in the house electrical panel, but I guess that you have learned the drill: only one appliance on at a time. Try moving the oven to the working side of the socket (the two socket sections can be spit apart and power each half from a separate house breaker and wiring). If the oven now works, check for a tripped breaker in the house panel. If the oven still doesn't work, look for a reset button near the cord entry point. Many heating type appliances have a thermal fuse that opens when things get too hot, but you need to get inside the cover where the cord enters.
Oct 11, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Oster microwave/grill
ha, had the same problem, just call the oster custumer service and they can send you a new one for $5
1-800-968-9853
Oct 06, 2007 | Oster 4877 / 4878 / 6209 Toaster Oven with...
Panasonic NN-SD688 Microwave Oven Logo
Top Panasonic Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Panasonic Toaster Oven Expert? Answer questions, earn points and help others
