Question about WSM 1998-1999 Yamaha Gp 800 Cc Jet Ski Motor Mount
Jet ski troubleshooting
Gets water in engine
    Renaissance:
    An user who is expert in 3 categories / brands.
  • WSM Master
  • 1,190 Answers
What make of ski ?? does it get water in the engine all the time ? more info please ?
Posted on Jun 20, 2014
Polaris troubleshoot
clean impellor and water intake ! run up on hose and check cooling ok !
Jul 28, 2014 | WSM 1993-1994 Polaris Sl 750 Cc Jet Ski...
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
damaged impellor or housing , grabbing air !
Dec 19, 2013 | WSM 1995-1997 Kawasaki 750 Zxi Cdi...
Kawasaki watercraft
compression check , 100psi or more ! battery and connections good ?
Jul 06, 2013 | WSM 1995-1997 Kawasaki Sxi 750 Cc Jet Ski...
My Yamaha Jet Ski 750, turned over Bro.. my Jet Ski, Yamaha 750, turned over and after that.. I pulled out of the water took the spark plugs out, put DW40 in the cylinders and nothing happened.. the e
sounds like you hydro locked it and possibly blew out a reed in your engine intake or worse, you may have bent a crank rod. But before you go tearing it apart make sure all the water is out of motor and theres none in the fuel tank then put in a new set of plugs and see what happens,
Mar 18, 2013 | Water Sport
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
Jan 17, 2013 | Boating
Rolled our 2007 800 SXR - ended up upside down. Rolled it clockwise back to upright. Re-started it without looking into engine compartment. It ran 5-6 seconds then stopped. Now the starter can't turn the...
i would remove all of the water and then manually turn the engine over alot without starting it SOON to get the water out of the pistons- if it was hydro locked this might prove quite challenging.
Aug 06, 2009 | 2000 kawasaki VN 2000 Classic LT
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
WSM 1998-1999 Yamaha Gp 800 Cc Jet Ski Motor Mount Logo
154 people viewed this question
Top WSM Boating Experts
Fabrice Wolters
Stan Ford
spy1309
Are you a WSM Boating Expert? Answer questions, earn points and help others
