Question about Gear Head Mouse
Mouse keyboard combo, can i use separately - Gear Head Mouse
I have a Phillips Freevemts PC, that came with a wireless keyboard, mouse and dongle. The dongle no longer works, can I get a replacement?
The dongle probably has an USB connector. It is very common for
the connector to become bent, after numerous plugging and
unplugging, causing a solder disconnect between it and the
PCB board inside the dongle. Someone with the know-how
in soldering can help you resolder it, then it will be good as
new. Sorry, but such dongles are not for sale separately from
a keyboard and mouse combo.
Jul 16, 2011 | Computers & Internet
I lost the mouse for my Logitech Wireless Combo MK320. Can i order another seperately from the keyboard? If so, how would I go about it. Thank you.
I'm sorry to say that Logitech doesn't offer separate halves of their combo deals. There isn't even a copy of just the mouse for sale on Ebay that I was able to locate, which is normally where you can find things like that.
Jun 10, 2011 | Targus AMU18US Mouse
I am installing a new mouse and keyboard combo should I delete old drivers from provious Logitech product i had installed
For a Windows platform PC, the generic Keyboard/mouse drivers are provided by Microsoft, you don't have to remove these drivers.
If you are using the software for the Keyboard/mouse the devices, you can remove these software, and install the new software for your new Keyboard/mouse combo set.
Hope it helps.
Oct 16, 2010 | Computers & Internet
It does not work
Usually for the combo mouse and keyboard you need to install a driver for that... try checking the manufacturer's website for combos
Mar 27, 2010 | Computers & Internet
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
Need installation software for my ik-0626rp wireless combo
are you install the drivers mouse and keyboard properly.
if not install then please install the driver first to solve this problem.
if you have not the driver then tell me.
i can provide the driver link.
thanks
you can further help me
Apr 07, 2009 | DPI ITSG Wireless Desktop IK-0626RP...
Keyboard
I've used the 62150 black combo on XP Pro, not the 62150N Deluxe silver combo, for years without a problem after setting them up. Had 2 PS2 ports so had to use an adapter for the keyboard connector. To sync, press the ID button on the receiver. LED will blink fast for a few seconds, then slower Press the ID button on the mouse and keyboard while receiver is still blinking (need a pen or something for the mouse button). If the receiver LED blinks whenever you move the mouse or hit the keyboard, it is receiving the signal. If the OS does not recognize input, it could be the connectors (I had separate PS2 for mouse and keyboard each).
Their website does not provide driver downloads or much user support - stop posting the link for everything SLSL2000.....
Jun 14, 2008 | Sakar 62150 Keyboard
Bought two Sakar I Concepts wireless keyboard/mouse last summer at walmart and kept them to give as Christmas presents. I have found out from both people that I gave them to that the mouse works on both of...
I've used the 62150 black combo (not 62150N Deluxe silver) on XP Pro for years with no problem. Manual said to sync, press ID button on receiver and LED will blink fast, then slower. While blinking, press ID button on keyboard and mouse (need pen or something to press mouse button). If receiver LED blinks whenever you move mouse or hit keyboard, it is receiving. If OS doesn't recognize, may be connectors. I had 2 separate PS2 ports and had to use an USB adapter for the keyboard cable.
Mar 24, 2008 | Computers & Internet
Gear Head  Mouse Logo
13 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
brian soufane
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
