Question about Ricoh Aficio 1035 Copier
Ricoh 3035 error code sc322 - Ricoh Aficio 1035 Copier
benwabnick
  • 2404 Answers
SOURCE: Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Posted on Feb 10, 2009
  • 22 Answers
SOURCE: 1035 ricoh aficio printer with error code 322
Yes, the code is caused by toner getting into the laser unit. The laser unit likely only needs to be cleaned out. To do so, turn the machine of with the red rocker switch on left side of the machine. You will need to remove the front cover and the brown cover behind it. The mechanical counter is plugged into the brown cover so be careful not to damage the wires. The laser unit is the black plastic case you will see behind the brown cover. Be sure to remove the necessary screws and connectors. Be extra careful of the ribbon cable, it kinks easily and the contacts are easily damaged. The Laser unit will slide out, and you can remove the screws holding the top cover on. After removal, clean the interior of the case and mirrors. Do not use any liquid to clean it, preferrabley canned air and a lint free cloth. After cleaning, reassemble, turn the machine back on, and test.
Posted on Nov 19, 2009
M2Tech1
  • 313 Answers
SOURCE: FORGET USER CODE
if you go into the user toools via the 123button at top left look for the admin tools and go to address book there shoul be a list of users there.. alternatively go into sp mode via clear 107 and hold down the stop button till hte screen changes and then look for 5.mode and then scroll down till you come to the user code sp and turn it off as a temp measure.. youcan also setup a new user in the admin tools.
Posted on Dec 17, 2009
  • 165 Answers
SOURCE: please have you solution for the Error codes SC545
fuser over/under heat u need a service engineer to reset it
reasons
1 thermistors dirty
2 thermastat blown
2 lamps blown
try resetting it 1 st
press yellow key then 107 then hold red key for longer than 5 sec
go to section 5 (mode i think) then 810 sc reset press 1 then hash key off on
Posted on Nov 04, 2010
  • 183 Answers
SOURCE: Ricoh Aficio 1035 gives ERROR
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Posted on Jan 19, 2011
Ricoh afficio 1600ml error code sc322
laser code could be laser unit or board problem that lser unit plugs into.
Feb 01, 2017 | Ricoh Aficio Office Equipment & Supplies
My copier Ricoh Aficio 1515mf is writing call for service
You must specify the error, displayed in lcd, something like Sc322 or sc 548, etc..
That will tell the technician witch part to look,laser, fusion,optics etc. Penzance are right! Go on, post it!
Feb 13, 2015 | Ricoh Aficio 1515MF Digital Copier 15cpm....
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Ricoh 3045 error925
Hi, mahesh Van;
The error code sc925, it mean networking problem, check up your network, will be take care this problem.
Sep 09, 2013 | Ricoh Aficio 3045, 3035 Kit
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
Jan 14, 2011 | Ricoh Aficio 1035 Copier
Code error sc322
laser error code polygon mirror motor bad -Carl
Dec 06, 2010 | Ricoh Aficio 1035 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
Ricoh Aficio 1035 Copier Logo
24 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
