Aficio dsm 725 error code 793 - Office Equipment & Supplies
2 Suggested Answers
  • 109 Answers
SOURCE: nasushatec dsm 725 error code sc541
• Fusing thermistor defective or out of position
• Poor thermistor terminal connection
Entering SP mode
1) Press the following keys in sequence.
reset + 1+0+7+Hold the (stop) key for more than 3 seconds
enter copy mode
then
mode
Sc Reset
Excute
Exit
off / on the copier
END
Posted on Apr 12, 2010
Manual guide for aficio copier dsm 620
Most makers have a PDF file Manual by going to the makers site and navigating to the list of Manuals. Then you can either print your own once it is fixed or keep getting it online. For a few pages you can get copies for a modest fee or free at Libraries.
Jan 26, 2015 | Office Equipment & Supplies
My machine is Gestetner dsm 725 I have a functional prolem sc672 please I want to know the reason
Unplug machine. Remove connectors to the hard drive. Does it boot up now? Yes, then replace the hard drive. No? Then the controller board is defective.
Dec 13, 2014 | Gestetner Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
My dsm 725 screen not responding to touches. any way to reset?
Bad touch screen. Easy to replace with a phillips screwdriver.
Part number:
H3106173
Aug 26, 2013 | Gestetner DSm725 All-In-One Laser Printer
I have Gestetner DSM 730 and it give me an error of serial no: k8654300136, so the problem
how can I reset one copy Gestetner DSM 730 if screnn touch does not afiche we do not even know the code up above.
Feb 11, 2012 | Gestetner DSm730 Black and White Copier
How do I make gray scale copies on the Gestetner DSM 725
Once in service mode (CLEAR MODES KEY, 107, HOLD CLEAR STOP KEY) enter sp 2902-003, enter test pattern#16 and press start. press copy window and select paper size, press start key twice to start test print. press sp mode to return to sp mode display. Hope this helps
Jul 15, 2011 | Gestetner Office Equipment & Supplies
Error sc 326 in dsm 635
First of all check that the laser **** glass is still there, I've seen a couple of machines where the **** glass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
May 04, 2010 | Gestetner DSm635 Copier
2002 Ford Excursion drivers control module
It could be , but to replace it without testing would not be a wise idea . These modules can set DTC'S - diagnostic trouble code's .Having a qualified repair shop check it would be your best bet .
It's called driver seat module .
DSM Diagnostic Trouble Code (DTC) Index
DSM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Faulted DSM INSTALL a new DSM. REFER to Section 419-10 . B1530 Memory Set Switch Circuit Short to Ground DSM Go To Pinpoint Test J . B1534 Memory 1 Switch Circuit Short to Ground DSM Go To Pinpoint Test J . B1538 Memory 2 Switch Circuit Short to Ground DSM Go To Pinpoint Test J . B1663 Seat Driver Front Up/Down Motor Stalled DSM If the motor does not operate, Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). If motor operates, Go To Pinpoint Test J . B1664 Seat Driver Rear Up/Down Motor Stalled DSM If the motor does not operate, Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). If motor operates, Go To Pinpoint Test J . B1665 Seat Driver Forward/Backward Motor Stalled DSM If the motor does not operate, Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). If motor operates, Go To Pinpoint Test J . B1666 Seat Recline Forward/Rearward Motor Stalled DSM If the motor does not operate, Go To Pinpoint Test H (Navigator). If motor operates, Go To Pinpoint Test J . B1667 Mirror Driver Up/Down Motor Stalled DSM REFER to Section 501-09 . B1668 Mirror Driver Right/Left Motor Stalled DSM REFER to Section 501-09 . B1669 Mirror Passenger Up/Down Motor Stalled DSM REFER to Section 501-09 . B1670 Mirror Passenger Right/Left Motor Stalled DSM REFER to Section 501-09 . B1676 Battery Voltage Out of Range DSM REFER to Section 414-00 . B1703 Seat Driver Recline Forward Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator). B1707 Seat Driver Recline Rearward Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator). B1711 Seat Driver Front Up Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). B1715 Seat Driver Front Down Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). B1719 Seat Driver Forward Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). B1723 Seat Driver Rearward Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). B1727 Seat Driver Rear Up Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). B1731 Seat Driver Rear Down Switch Circuit Short to Battery DSM Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). B1735 Mirror Driver Vertical Switch Circuit Short to Battery DSM REFER to Section 501-09 . B1739 Mirror Driver Horizontal Switch Circuit Short to Battery DSM REFER to Section 501-09 . B1743 Mirror Passenger Vertical Switch Circuit Short to Battery DSM REFER to Section 501-09 . B1747 Mirror Passenger Horizontal Switch Circuit Short to Battery DSM REFER to Section 501-09 . B1950 Seat Rear Up/Down Feedback Potentiometer Circuit Failure DSM Go To Pinpoint Test J . B1952 Seat Rear Up/Down Feedback Potentiometer Circuit Short to Battery DSM Go To Pinpoint Test J . B1954 Seat Front Up/Down Feedback Potentiometer Circuit Failure DSM Go To Pinpoint Test J . B1956 Seat Front Up/Down Feedback Potentiometer Circuit Short to Battery DSM Go To Pinpoint Test J . B1958 Seat Recline Fwd/Backward Feedback Potentiometer Circuit Failure DSM Go To Pinpoint Test J . B1961 Seat Recline Fwd/Backward Feedback Potentiometer Circuit Short to Ground DSM Go To Pinpoint Test J . B1962 Seat Horizontal Forward/Rearward Feedback Potentiometer Circuit Failure DSM Go To Pinpoint Test J . B1964 Seat Horizontal Forward/Rearward Feedback Potentiometer Circuit Short to Battery DSM Go To Pinpoint Test J . B1987 Pedal Forward / Rearward Motor Stalled DSM REFER to Section 206-00 . B1988 Pedal Position Forward Switch Circuit Short to Battery DSM REFER to Section 206-00 . B1989 Pedal Position Rearward Switch Circuit Short to Battery DSM REFER to Section 206-00 . B1990 Pedal Forward/Rearward Feedback Potentiometer Circuit Failure DSM REFER to Section 206-00 . B1991 Pedal Forward/Rearward Feedback Potentiometer Circuit Short to Battery DSM REFER to Section 206-00 . B2312 Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure DSM REFER to Section 501-09 . B2314 Mirror Passenger Horizontal Feedback Potentiometer Short to Battery DSM REFER to Section 501-09 . B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure DSM REFER to Section 501-09 . B2318 Mirror Passenger Vertical Feedback Potentiometer Short to Battery DSM REFER to Section 501-09 . B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure DSM REFER to Section 501-09 . B2322 Mirror Driver Horizontal Feedback Potentiometer Short to Battery DSM REFER to Section 501-09 . B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure DSM REFER to Section 501-09 . B2326 Mirror Driver Vertical Feedback Potentiometer Short to Battery DSM REFER to Section 501-09 . B2477 Module Configuration Failure DSM INSTALL a new DSM.
Nov 30, 2017 | 2003 Ford Excursion
Nasushatec dsm 725 error code sc541
Entering SP mode
enter copy mode
then
mode
Sc Reset
Excute
Exit
off / on the copier
END
Apr 12, 2010 | Office Equipment & Supplies
k24674
jasbo
jasbo
