Question about Ovens
Stoves model 059040414
How to get the timer on the oven to work to get the oven on
4 Suggested Answers
  • 8 Answers
SOURCE: I have a Stoves Fan Oven Model no.059040414 which
It appears to be a wiring fault.
Suggest a job for an electrician
Posted on Sep 02, 2009
ginko
  • 19396 Answers
SOURCE: we have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Posted on Mar 05, 2010
  • 250 Answers
SOURCE: How do I fit a
First, a handbook is available, but I will need an email address to send it to you.
TURN THE POWER OFF.
To replace the switch, you have to take the whole oven out of its kitchen furniture housing and then take the top off. ) It is held in place by normal wood screwes) All the knobs on the front panel are pull off/push on and you have to remove them. Once you have the knobs off you have to remove the glass control knob panel. On the lower edge of it at either end you will see two cross head screws going upwards. Remove these. Now the only thing holding this in place are I think three lugs on the top of the glass panel that go up and in to the top of the cooker. With a bit of fiddling, the panel should now come off, leaving you free to access the switch for replacement.
I think you will find that the thermostat pipe will link into the top back of the top oven so this has to be very carefully replaced as well, which additionally may require the back of the oven to be unscrewed.
Best of luck!
Posted on Nov 08, 2010
I have kenmore c880 model stove , both oven and stove are not heating up after shifting to new house...any tips to get it resolved? Only oven light is working.
Make sure there is 220 volts at the wall socket where you plug the oven into. A faulty circuit breaker in the power panel on your house will only let 110 volts get to the oven so the lights and timers will work but not the heating elements.
Sep 09, 2016 | Kenmore Ovens
The display has failed. Do how need to replace it and all the controls? If so, how, or is it better to get an engineer in? The model number is 059040414.
If the timer/clock has failed then you will need a new one and it is available form espares at about £85 pounds. If you have not worked with electricity and not that practical then you should call an engineer in. You will probably have to take the entire oven out of its housing, to take the top off, although the front panel comes off relatively easy.
Dec 01, 2010 | Stoves 720EF Electric Double Oven
Kenmore Classic Wall Oven Model # C97047191-2 Serial # NF91008197 nothing on it works (was fine last night) checked the 3 fuses under the stove and the breaker is good on the electrical panel. Is there...
I think that the ONLY problem is to set properly the TIMER; The TIMER is set OFF and the OVEN does not work; try to push and/or release the timer buttons and it will work. I have the same problem and it is very unfortunate that I have no manuals.....
Oct 05, 2010 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My stove works but my oven wont, and the light of the oven wont turn off
Without a model number, my guess would be a stuck relay in the electronic clock/timer. Replace the Electronic clock/timer.
Jan 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't work beacuse of the timer on the stove.
It depends on the make and model and wether it is a digital clock.
But generally if you press/turn the larger knob this will reset the clock and return the oven to manual cooking .
Jan 01, 2010 | Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Using the oven timer of a Stove oven circa 1999
The normal STOVES label is on the rear of the oven, but there should be a small label visible on the left hand side of the lower oven when you lower the door. There should be a long product number on that with the unit serial number. The product no can be used to identify the unit. STOVES may be able to help here.
I have a 720EF handbook scanned and it is on my BT Digital Vault, so if you want this version give me a valid email address and I will ensure you receive a copy.
Mar 28, 2009 | Stoves 720EF Electric Double Oven
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Ovens Logo
11 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
