Question about Sony RM-U25 Remote Control
I need ir code for my lg tv - Sony RM-U25 Remote Control
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
Program remote to LG TV
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for addressing your remote to your TV for each of our different models of remotes. You should be able to locate your remote model number on the back of the remote at the top usually a 2 to 3 digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes and the instructions for addressing your remote to your LG TV. I hope you find this information useful and if you have any further questions feel free to email me directly at Cheri.Torres@Dishnetwork.com.
Codes for a LG TV
3.0, 3.1, 3.2, 3.4 IR remotes - 678, 506, 520, 627, 766, 211
5.0, 5.2, 5.3, 5.4 IR remotes - 520, 505, 678, 512, 766,
4.0 and 4.4 IR/UHF remotes - 678, 156, 520, 023, 627, 766
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 520, 654, 678, 564, 506, 500, 627
20.0 IR remote and 21.0 IR/UHF remotes - 627, 505, 520, 553, 773, 718
Instructions for addressing the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all the mode lights light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Apr 17, 2011 | DISH Network IR Remote Control
I need the code number for my new lg tv so i can make my control turn my tv on and off
The remote codes we have listed for LG are as follows; 627, 766, 124, 520, 666, 773, 521, 505, 653
To program the remote, hold down the cear "tv" button until all four mode buttons are lit.
Next, Press the three digit code follwed by pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 01, 2011 | DISH Network IR Remote Control
Brand to pick to promgran a lg tv to dish remote for power on , ect ?
Hello, this is Cheri Torres with DISH Network customerservice. I came across your questions and wanted to see if I could help. :)There are a few codes that you can try to program to your remote in order toget your remote to perform the TV functions. We have different codes fordifferent models of remotes. You can find the model number of your remote onthe back of the remote at the top. This model number usually consists of a twodigit number with a decimal point i.e. 3.4 etc. I am going to list thedifferent codes for each of our most common IR remotes. For the 3.0 IR remotethe codes that work most often are going to be 678, 506, and 520. For the 3.1IR remote 520 and 506 are the most commonly used. For the 3.2 IR remote 506,627, and 520 are the best codes. The codes for the 5.0 IR remote are 505, 520,and 678. For the 5.3 they are 520 and 766. The 5.4 IR remote is the last remoteand the code is 766. I hope you find these codes useful in getting your IRremote addressed to your LG television. If you have any further questions orconcerns feel free to post back here and I would be happy to help. :)
Dec 12, 2010 | DISH Network IR Remote Control
I need a code for a v-zon tv3200 remote wont work,,,direct tv doesnt recognize this brand direct tv no help
I would suggest you try and use the codes Direct has given you for Zenith, Goldstar & LG tvs. There a good chance that's who made the tuner in your tv. Hope this helps.
Dec 05, 2010 | DISH Network IR Remote Control
I have a 60 inch lg tv. The remote just stopped working Put in new batteries. Tv button lights up on remote but will not turn tv on.
Let me know model number of your 60 inch LG tv to find out possible cause of no remote operation.
I do not think that IR receiver is bad in your tv. Regarding dusty IR receiver lens, you can confirm it by sending remote signal by very close distance to tv.
There are few other possibilities of no remote operation problem instead of bad IR receiver.
Aug 25, 2010 | LG 42LC2D 42 in. LCD HDTV
I need codes for a LG TV for Dish Netwrok remote
lqaztec4
I have provided a link with instructions on how to program your DISH remote to your LG TV. Just click on the link, select your receiver model, and then follow the directions. At the bottom of the page is a link with the TV codes. Again, select your receiver model and look for your TV model. I hope this helps.
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Jun 27, 2009 | DISH Network IR Remote Control
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Jun 22, 2009 | LG 47LC7DF 47 in. LCD HDTV
Remote works but TV does not receive
The IR reciever failure rate on LG tv's is fairly high. A few things to try first.
  1. Clean the IR window on the TV.
  2. Fresh batteries in remote(even though it works other devices)
  3. If you have a universal remote, program it to the tv for testing puposes.
Let me know your findings and we can go from there. Lone99star
Jan 26, 2009 | LG 42LC2D 42 in. LCD HDTV
My LG remote control turns two TV's on simultaneously
I had the same problem and we cut up a stick on lable and placed it over the end of the remote . It weakened the signal enough to where it would not change the other tv/tvs. We colored in the white lable with a black marker and you dont even notice it there.
It took alittle playing around with but it was much cheaper than buying a remote.
Dec 01, 2008 | LG Shine KE970 Cellular Phone
Televison & Video Logo
13 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
