Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Please help SME
The LCD Screen of my Cannon Elph SD 200, all of a sudden,  will not light up. It will illuminate to review pictures or to take movies, but not to take pictures.
Can you help, your assistnce would be greatly appreciated. I can not find the solution in my manual. I went into the menu to try to resolve, but could not.
Thank you and have a wonderful day,
Rita Witherly
  • rwitherly Oct 27, 2007
    I look forward to your respones.
  • rwitherly Oct 28, 2007
    Thank you. I was able to solve it. It turns out the dispoe button had been hit and once pushed again the LCD was back.
Still under warranty? We sent our camera back for repairs after we had similar issues and the Canon support was fabulous. We could take movies but not stills (pictures).  Call for a Return Authorization number first. We had our camera back in a week or so.
Posted on Oct 28, 2007
Cannon powershot s3is turn on to take pictures and the led screen is black cant take pictures everything else works
this is a normal occurrrence in devices containing CCDs and does not constitutes a bad functions. (tHIS image will not be recorded when still photo, but it will be recorded when shooting movies.
Remember the in the LCD monitor will darken in strong SUNLIGHT or bright light.
Sep 22, 2012 | Cannon Cameras
My SD630 will not allow me to review pictures.
The mode switch malfunction. Try to open the camera, drop some alcohol to clean the switch.
Aug 02, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cannon SD 750 - when i try to take a picture a black screen appe
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jul 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Display of my Cannon Power Shot SD 630 Digital ELPH: NO IMAGE
i think you camera,s software is corrupted
go your canon customer center for repair it
Dec 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Screen display problem
It sounds like your "backlight" went out. This is a tiny compact fluorescent bulb in the LCD that lights up the screen. There are usually two reasons for this 1) the bulb burns out or 2) the little circuit board that powers the light fails, this is called the "inverter board" and is either in the "lid" (screen part) of the laptop or in the main base of the laptop. That's why there is a really dim picture. There are two parts of the LCD, one to produce the picture and the bulb that illuminates this picture so you can see it easily.
There's no easy way to test this. You will either have to replace the LCD or replace the inverter board to check. Usually the problem is with the inverter board, which is good because it can be easier to replace and a lot cheaper than a new LCD screen.
You can check HERE to see if any of these guides looks like they might help you replace the inverter. They don't have your exact computer, but they do have several models that are similar.
If you take it to a commercial repair shop it will probably cost between $250-400 to repair. If you contact someone good through Craigslist or some other similar service in your area, you should be able to find someone to do it for about $50+ parts.
Good luck.
Oct 08, 2008 | Acer Aspire 3690-2196 Notebook
I have a Canon PowerShot SD600 Digital Elph, and the screen on the back has turned off while I try to take a picture. It will show on the screen when I try to take a movie, but the photos is just a black...
Did you accidentally hit the DISPLAY button on the back of the camera. It turns the LCD screen on and off in picture mode to save batteries.
Jun 23, 2008 | Canon Cameras
The image is getting blurred
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Lcd screen
Cannot get images deleted
Feb 23, 2008 | HP PhotoSmart M437 Digital Camera
Cannon powershot sd 300
flash may have been dislodged and out of true. or may be the lens is out of alignment or a shutter blade is not functioning. Dropping them sure does them no good at all. Into the repair shop with it
Jun 03, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
