Question about Garmin Fishfinder 100 GPS Receiver
My garmin100 wont turn on,but sometimes when am going along on boat it jus comes on and then off,,wots wrong with it,,
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 29 Answers
Your GPS requires servicing. There may be an intermittent power supply to or in the device.
Posted on Feb 15, 2014
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
My chevy s10 died going down the road. It turns over but wont start
I have 94 s 10..4.3 v6. it does the same thing have replaced fuel pump and filter,ignition module,cap rotor plugs wires,coil,ground strap...driving down the road jus dies like the key got shut off....for a while when troubleshooting through the parts you could get it to restart.....now when it dies it cranks really hard when trying to restart..ive checked the timeing its fine....if i wait a few min it will usually start...sometimes it will show a check engine light sometimes not......never know when it will happen sometimes jus down the the road from the house sometimes 100miles down the road......sometimes three times in a mile sometimes not for weeks at a time..Wtf...Im ready to shoot it like a lame horse....its a shame too its a sharp lil truck thats a two owner and never spent a night outside in its life...i knew the original owner ...i bought it with 90,000 on it it only has 148,000 now and still looks like new...
Apr 22, 2013 | 1994 Chevrolet S-10
I have a 2002 sunfire... and i have trouble turning it on. Once it startes it is stuck there because it will not turn at all. Once it is in this position the wipes wont work, the windows wont roll down,...
sounds like you need a new ignition, reason nothing works cause once it doese turn over n starts the car the tumbler is stick in the starting position jus not far enough to keep the starter engaged but far enough the it still trying to go trough the start process which cuts the power to everything else till the ignition returns to the on postion
did you try jus turning the ignition far enough to when the starter engages jus let go of it so the car doesnt start and see if everything else still doesnt work if it dont i belive its the igniton
also with out starting it or engaging the starter as in just turning the key on to get power does anything work?
Jul 12, 2012 | 2002 Pontiac Sunfire
150 johnson wont idle wot great
start engine while in water with slightly high tickover , remove throttle cable and find throttle stop screw and adjust till 800rpm holding the throttle arm against the stop and see if you can select forward gear without stalling ! depends what size pitch prop your using as you mite need tickover slightly higher but as long as it selects without stalling then ok ! as long as it doesnt jump forward , in gear should be 800rpm + or - 100 max ! if still stalling then possible requires fuel system cleaning !
Jun 03, 2012 | Light Outboard Motor Boat Bass Fishing...
My car doesnt want to star sometimes i dont know what is wrong with it have jus 55000 mls
the starter was changed out in my 2000 lincoln ls but it still wont crank
Feb 20, 2010 | Lincoln LS Cars & Trucks
Hi i have a sony vaio LT series all in one pc, the thing is my wirless has stopped working, it happend b4 abt 6 monthes ago but used system restore to put it back to the previous settings and it sorted it...
GO to your manfacture webpage, then go to drivers download, choose your laptop model, and your operating system, and download the wirless driver, then install it, and this will fix your problem.
thanks for using Fixya
Oct 05, 2009 | Computers & Internet
Radio wont come on
Go to the very front (or back) of your owners manual (NOT in the radio section) and you may find the codes there. If not, go to your GM dealer. (Should be inexpensive job.)
Aug 18, 2009 | 2000 Pontiac Grand Am GT
I ahve a 1959 johnson 50hp v4 it makes a funny grind noise when i go wot and then dies out wont start again
Check and make sure that your flywheel has not come loose. That would cause the noise and if it is loose it will mess the timing up and cause it to die. If it is loose then remove it and make sure the half moon key did not break.
Aug 09, 2009 | Boating
Sometimes it just wont start. turns over jus .twont
check fuel pressure at time of no start. no fuel pressure test PGM-FI main relay
Jul 22, 2009 | 1999 Honda Accord
My sansa wnt work!
me 2 mine wont work either!!!!!!!!!!! wot the hel do we do!??
Aug 25, 2008 | SanDisk Sansa Clip MP3 Player
Garmin Fishfinder 100 GPS Receiver Logo
20 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
