Beomaster 4500 presets out of function
Hi need code for 4500 R E.O.N serial number M080554
try 6148 that should be it
Once the unit has been turned on the display will show ' CODE - - - -'Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
May 18, 2015 | Car Audio & Video
Owners manual bang and olufsen beomaster 6500
hi,
You can will get the manual for B&O Beomaster 6500 User gide in the following link. If you cant view the manual then sent me your email address. if so i will sent the user gide to that.
http://bang-olufsen-deboer.nl/gebruikershandleidingen/audiosystemen/beosystem6500_engels.pdf
OK
Oct 01, 2011 | Audio Players & Recorders
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
How do I enter a 4500 radio code in a ford fiesta
Ford Code Entry Instructions
CODE - - - -'
Sep 01, 2010 | Ford Car Audio & Video
Hi, i need a code for my stereo model no-4500 rds sereal no-m 141770 thanks
Try code 5384
Jan 17, 2010 | Vehicle Parts & Accessories
Beomaster 2400-2 jumps radio station
Check the r/c is not causing this fault.Clean around the no4 pad.A b&o dealer should still be able to look at this unit assuming all their technicians are not youngsters given its age!
Aug 22, 2009 | Bang and Olufsen Audio Players & Recorders
I have a Beomaster 2400-2 which jumps off the station or piece of equipment and defaults to the radio channel 4 then goes dead. I have tried cleaning the front but although a lot of dirt has come off it...
hi,
thought I was the only one with a problem like that.. I experienced exactly the same problem. I selected a random radio station or phono and the amp switched sporadically to station 1, then off. I realised that the power cabling was in very, very bad condition, so I replaced it. and since than it works. I have tested it now for several days and it does not switch off or to another preset anymore.
hope this helps.
cheers, lars
Aug 12, 2009 | Audio Players & Recorders
BEOMASTER 4000 No sound from one speaker. Tried swaping cables etc.- problem lies in the output from amplifi
Hi...
Try one other thing..headphones. If there's only 1 channel in the headphones then you'll need to take it to a tech.
Depends on where in the country you are as to a good tech.
I know some...even me in the Northeast
Jan 11, 2009 | Audio Players & Recorders
Sound distortion on beomaster 3300
There is a defect in the pre-amp section of the unit. Without seeing it and taking a few measurements, I can't give you any particulars. A rough estimate for a repair wouldbe about $10-$25 in parts plus the local labor rate.
Dan
Sep 30, 2008 | Audio Players & Recorders
19 people viewed this question
 Grubhead
Grubhead
