Question about Nikon FM3A 35mm SLR Camera
Red flashing lights in viewfinder. Replaced batteries. Still flashing. What is wrong?
Have shot two rolls through very good condition fm3a. Then flashing lights red in viewfinder. Have replaced batteries but still have flashing lights top left of view finder between plus minus sign and flash sign. Is this the flash ready light which has come on without reason ? Have never mounted flash.
    Top Expert:
  • Nikon Master
  • 14,162 Answers
Posted on Jul 18, 2016
2 Suggested Answers
poolseman
  • 206 Answers
SOURCE: dark view in view finder
Sounds like a lens diaphragm problem ( lens stays closed down to F16 and that is why you have a dark viewfinder ). Remove lens and see if you can activate the aperture mechanism via the activator which protrudes from the rear of the lens. You should get nice and brisk action from the aperture . If the movement is sluggish or the lens stays fully closed then your lens needs attention.
Posted on Sep 16, 2007
Olympus e420 no live view black images
are the photos on the memory card? LCD could be shot or loose.
Mar 12, 2014 | Olympus Cameras
I recently brought a nikon fm2a and a fm2t. When I fire both shutter at the same time with 1 sec shutter speed.The fm2t has a slight delay in closing the shutter compare to the fm3a. To my knowledge, both...
You need to have the camera serviced. It sounds like you shutter may be sticking and any loose part should be an instant red flag. It had to come from somewhere and it could be related to your shutter delay problem.
Jan 31, 2014 | Nikon FM2N 35mm SLR Camera
All shutters do have a certain tolerance. Because you don't say anything about the real time the shutter is open, It is impossible to tell what camera has a "correct" shutter time. Or if they both are of. I used to calibrate my camera's, because most of the time the next time is exact twice or half of the former time on the dial. Even with the band new cameras in the past, I shot one or two rolls, to check if my settings were correct. Never had any trouble with shutter times, because I never checked how long the were open.
Jan 31, 2014 | Photography
Nikon F65 won't auto-focus or take shots
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Mar 09, 2017 | Nikon F65 35mm SLR Camera
How to know if battery is low?
When you turn the power ON (turn the dial from OFF to AUTO), in the viewfinder a green lamp on the right will light for about one second, this indicates battery level is sufficient.
So, it's not possible to know how much longer the battery will last etc, best to carry a spare battery.
As a rough guide, the manual states the shooting capacity is 18 rolls of 24-exp film with 50% flash use.
Hope this helps :)
Oct 31, 2010 | Canon Sure Shot A1 35mm Point and Shoot...
No motor when switched on and 2 red lights flash
Your Sebo has switched itself off to prevent damage. The flashing red lights indicate that the brush roll is jammed and that there may also be a blockage somewhere. You should take the brush roll out and make sure it is clear of obstruction, and also check for blockages (in the inspection flap on the underside, and in the plastic pipe and the flexible hose), and check the condition of the filter in the bag compartment. If the brush roll is clear and the problem persists, you should seek help from a professional repairer as something is probably broken inside (although with Sebos this is extremely rare). Good luck!
Jan 29, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Red flashing indicator in viewfinder of my Canon XL1E
Hi . .  I downloaded the manual . . found I needed to replace the 3 volt lithium battery located on the underside of the hand grip for the zoom. Changed the battery . . . No red flashing icon in the viewfinder.
Cheers
Steve
Feb 28, 2009 | Canon XL1E Mini DV Digital Camcorder
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Whitebalanc; red cast over pictures
Greetings...
The red or orange cast comes from a warm light source since you have the auto white blance off...
Got to your menu and turn the auto white blance back on and then try taking the same picture under the same lighting and see if that corrects your problem...
Ed
Apr 08, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Nikon FM3A 35mm SLR Camera Logo
77 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
