Question about Exercise & Fitness
Life gear treadmill error 2 - Exercise & Fitness
5 Suggested Answers
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
anupam19
  • 263 Answers
SOURCE: I have life gear treadmill.
you need to recalibrate your meter
Posted on Mar 16, 2011
  • 1196 Answers
SOURCE: I have a Life Gear
I will suggest you try reset it, Press POWER to turn off the treadmill, At the same time, press and hold the +, -, and POWER keys. Continue holding all keys until their is nothing on the screen display. Release the keys. insert the key properly and see what happens. With that, the problem should be solve.
Posted on May 01, 2011
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    Lifefitness TR 9000 treadmill - 1997 model
    Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
    Apr 28, 2010 | Life Fitness 9000 Next Generation...
    Feb 20, 2010 | Exercise & Fitness
    Error 1 message on older life fitness t3 treadmill
    Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
    Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
    Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
    FET Error
    FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
    Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
    Life fitness treadmill display: transistor error-won't run
    This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
    Solution
    Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
    Feb 28, 2009 | Life Fitness Remanufactured Next...
    Exercise & Fitness Logo
    12 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
