Question about OKI B4250 Led Printer
Red light flashing
Printer wont print anything at all.. And the furtest light on the right of the printer keeps flashing
  • 161 Answers
You need a new toner bottle.
Posted on Nov 02, 2007
  • Felix Lopez
    Felix Lopez May 28, 2008
    Since your printer does not have a text panel for user intervention, it comes with a management software that diagnoses and reports in nice terms what is wrong with it. Your flashing light is low toner or need for drum replacement. If it is toner, the light goes away automatically. If it is drum, you need to install the mentioned software in order to reset the drum count. There is no other way to clear that error. The software name is "Status Monitor" and it can be downloaded in the "Drivers" section at www.okidata.com.
    Be blessed.
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Maintenance warning/technical issue message stops printing
You just need to reset your printer. Google search a resetter program for your printer model.
Jan 10, 2010 | Epson Office Equipment & Supplies
Ink light keeps flashing
reset the printer by turning it off, waiting 10 seconds and turning it back on, also right click on My Computer and select manage..go to services and stop and restart the spooler service
Jul 24, 2009 | HP DeskJet 930c InkJet Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
Sep 18, 2008 | HP DeskJet F380 All-In-One Printer
Printer
Add a bit more detail and I may be able to help you.
Under what situation does the light come on.
Is it a constant light or a flashing one.
Does it happen at the same point every time (i.e. startup, when beginning a print job, half way through a print job etc) or is it intermittent.
Have you had any other problems recently like a paper jam, have you changed anything (ink for instance).
Give as much detail as possible please.
Sep 10, 2008 | Epson Stylus 680 InkJet Color Printer
FS 920 printer
how do it lits? flashes or permanent? and kindly indicate if its attention indicator or ready indicator...
cause in every flash and lits of that indicators have meaning...
Feb 08, 2008 | Kyocera FS-920 Laser Printer
Red light on my hp photosmart 7850 keeps flashing
Same problem red light flashing and a picture of a little box with an arrow pointing right in the screen??? what the hell does that mean?
Nov 22, 2007 | HP Photosmart 7850 InkJet Printer
OKI B4250 Led Printer Logo
400 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
