Question about HEWLETT-PACKARD Officejet 4500 All-in-One InkJet Printer
Blinks upgradeprinter when I want to print, the default printer blinks "upgradeprinter"
I'm printing labels on my printer. After each run, the printer prints out an hp advertisement page for buying supplies, etc. Almost like a test page. How can I delete this annoying and wasteful...
Try this:
But first print a configuration report.(contain IP address)
Configuration Report
Release GO after LED begins blinking.
Now:
Reset the factory default settings (cold reset)
Turning on the printer while pressing the GO and CANCEL JOB buttons restores the factory default settings.
1 Turn off the printer.
2 Press and hold the GO and CANCEL JOB buttons.
3 Turn the printer on and continue to press and hold the buttons until all three LEDs are blinking.
4 Release the buttons.
Jul 13, 2011 | HP LaserJet 1022n Printer
Blinking yellow light with printer offline status.
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Jan 08, 2011 | HP Deskjet D4160 InkJet Photo Printer
My printer hp deskjet d1360 offline status and the lamp is blinking
Dec 22, 2010 | HP Deskjet D2360 InkJet Printer
My computer doesn't send picture to be printed to my hp photosmart 8450. I have Windows Vista and it worked before. Now why does it show an error in the printer info and also, this printer is set as...
If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
Sep 21, 2010 | Dell Office Equipment & Supplies
My lexmark blinks green but wont turn on everytime i try to turn it on it just spins for a second and goes right back to blink mode
The flashing green light probably means communication error, it is not normal.
These Dell/Lexmark comm. errors can be difficult.
Try this:
Start > Control Panel > Printers2_bing.gif and Faxes > RtClick Your Printer (default) > Properties > Advanced (on mine) > Check "Print Directly to Printer"
Feb 12, 2010 | Lexmark Z2420 Printer
I send a document from WORD (ms vista) and nothing happens. Printer window shows a document to print.. but nothing ever prints. No lights blink as usual, nothing. restarted computer, still nothing.
Vista has most drivers, and certainly supports your printer.
Try this routine.
First turn on your computer.
Now, turn on printer, and connect the USB.
Vista will recognize it.
i) Go to printers and faxes and set your printer as default, because there are other software like One note which could be default.
OR ii) Go to your word document, ctrl+P for print settings, choose your printer from the drop down menu
Jun 03, 2009 | HP Deskjet 6940 InkJet Printer
WROTE A LETTER, DOES NOT WANT TO PRINT/ OTHER THINGS DON'T EITHER
Is the power coming properly, Is the printer blinking ok.
Find out the Printer is it is Set to default and not goes in offline, during spooling the print.
Let me know if you need further help
Regards
Ellin
Sep 28, 2008 | Office Equipment & Supplies
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
Printer will not print.
go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
Oct 05, 2007 | HP Deskjet F340 All-In-One InkJet Printer
Open Questions:
See all HEWLETT-PACKARD Officejet 4500 All-in-One InkJet Questions
HEWLETT-PACKARD Officejet 4500 All-in-One InkJet Printer Logo
79 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
