Question about Intex Pool & Spa
I need to seal the bottom of my Intex pool (5m in diameter) what is the best way to seal it?
  • 366 Answers
SOURCE: pacer does not run on INTEX pool pump, no
make sure to check the diaphragm inside, check for deformity or debris stuck in it. You can take the unit apart just below the wagon wheel and push the white tube downward to expose the diaphragm.
Posted on Feb 03, 2010
  • 2841 Answers
SOURCE: what is the best model filter pump for an 18' X
No doubt about it the Intex Krystal Clear Deluxe Saltwater System & Filter Pump. No more chemicals to add and no more money to spend. Just buy salt. Could not be easier. I own one myself. http://www.intexcorp.com/saltwater_02.html
Posted on Jun 01, 2010
  • 8404 Answers
SOURCE: I've been reading the blogs and have ascertained
You have about 8588 gallons of water in your pool ... One inch of water contains about 159 gallons in your pool. You should consider a 6 hour turn over rate. I recommend a high rate sand filter with at a minimum 1.5 sq feet of filter area. You need to move about 24 gallons a minute to achieve the 6 hour turn over rate.
Continue your research with these figures at hand.
Thanks for your interest in FixYa.com. If you found this information helpful, please vote ...
Posted on Aug 02, 2010
Testimonial: "Thank you for the information - very helpful"
briones93
  • 119 Answers
SOURCE: I have a 15x 42" intex metal frame pool an i also
Most likely you are not. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
Posted on Jul 23, 2011
espressonist
  • 1711 Answers
SOURCE: I have a 24' round
The purchase of the salt water system will only helped you with not needing to pour chlorine in or float tablets.
You will still need to use chemecals like.
Use a good stabilizer to hold the chlorine level longer
Use a non foaming algecide once a week
And also use a water clarifying product once a week
Also cloudy water is because of not enough sanitizer mixed with a crappy pump from index
So now for your size of your pool you have a 13000gl pool you will need a 4500gl ph pump
A pool needs to be turned over at LEAST 3 times a day so for me it takes at least 8 hours of filtering alone this does not include making chlorine.
Bottom line y
our pool has about 13000 gallons, you would be looking for an 8 hour turn over rate, A 1.0 hp pump, rule of thumb, will move 35 gallons per minute, should be moving 2000 gallons per hour and your turn over rate is about 4 1/2 hours. This will avoid to run your system 24/7 between generating and straight filtering
Posted on Jul 25, 2011
Leaky valve from pool to filter tightening doesn't seem to work
need new seal if cannot get one need new valve
Jul 11, 2014 | Intex Pool & Spa
I need filter cartridges for Intex Spa
sometimes these can be hosed off with a garden hose and reused a couple of times..
Mar 06, 2014 | Intex Pool & Spa
Repair multiple leaks in INTEX Pool bottom
need more info are you able to drain pool? if so coat with water sealant paint
Feb 15, 2014 | Intex Pool & Spa
I have a residue at the bottom of my pool. It will not vaccum out just relocates. When the filter is running the water is white looking.
Sounds like you may have a torn pleat on your filter or may not be properly installed and sealing correctly???
Jul 21, 2011 | Intex Automatic Salt Water System for ...
I have the 12'x30" Intex Easy Set pool, and there is water leaking from the bottom of the pump, Ive tried to figure out why but i cant find the problem...any suggestions?
YOU MIGHT CHECK THE GASKET INSIDE THE IMPELLR CASING AND MAKE SURE THE SCREWS THAT HOLD IT IN PLACE ARE TIGHT ALSO CHECK YOUR SEAL BETWEEN YOUR PUMP AND FILTER. THERE IS ALSO A LARRGE NUT UNDER THE FILTER HOUSING THAT COULD WORK LOOSE. I WOULD ALSO CHECK ALL O RINGS AND MAKE SURE THEY ARE PLIABLE AND IN GOOD SHAPE.
Jul 30, 2010 | Intex Easy Set Pool 15x36
How many gallons of water in the intex pool 15 x 36
I presume you are speaking 15 feet in diameter and 36 inches average depth. 3976 gallons 176.7 square feet
Jul 21, 2010 | Intex Easy Set Pool 15x36
Trying to find how many gallons are in a swimming pool thats 4 foot deep and 18 foot in diameter?
7,610.... radius (1/2 of diameter) squared, times pi (3.14), times depth, times 7.48 (gallons in a cubic foot of water..Better check my math!!!! LOL
Jun 29, 2010 | Intex Pool & Spa
How many gallons of water does this pool hold?
CIRCULAR POOLS
Diameter x Diameter x Average Depth x 5.9 = Total Gallons
Example: pool_gall_round.gif
Jun 12, 2010 | Intex Easy Set Pool 15x36
Intex Easy Set 530 Gallon swimming pool filter pump is leaking. How do we get it to stop?
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Jul 02, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
Pool & Spa Logo
14 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
