Question about Canon Pixma MP990 InkJet Printer
Scanner will not started - Canon Pixma MP990 InkJet Printer
How to get windows to see the scanner every time.
Buy and install the 'Viewscan" scanner driver utility.
Then: Found that for windows to reliably see the scanner start windows, go to device manager, turn the scanner on and as it goes through its setup, right mouse click and select "scan for new devices" Windows 7 will now see the scanner right away.
May 13, 2014 | Acer ScanPremio 1220ST Flatbed Scanner
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Sep 17, 2013 | Epson Perfection V500 Flatbed Scanner
    I want to scan documents but i don't know how to do it. please give me the steps to operate the scanner
    Title: Scanning a document
    Hi, at first connect your scanner with your pc then-
    ?? Install your driver
    ?? After installation restart your computer.
    ?? When your computer start, go to "Start " and see the new installed software, open it and choose "Ulead photo Express" any thing which is your scanner supported.
    ?? Then open your scanner and put document into the scanner.
    ?? Close the cover.
    ?? In scanner a scan button is there , just push it.
    ?? Scanning will be start automatically.
    Thanks!
    May 13, 2011 | Computers & Internet
    I have a hp g2410 flatbed scanner when he scanner is powered on the light is glowing but the scanner does not make a move and is not scanning.
    i have a problem in my hp scanner g2410 scaning start and the meassage displayd start the activex controll on this page
    Dec 23, 2010 | HP ScanJet 2400 Flatbed Scanner
    Epson perfection 2580 scanner will not start. Programs installed w/cd. Epson updates added. Just says" scanner can not start"
    The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
    Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
    Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
    I hope this helps.
    (scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
    Apr 26, 2010 | Epson 2580 Perfection Photo Scanner
    I have never used a scanner please explain
    If you are just installing the scanner, follow the setup instructions that came with it, and make sure the software gets installed. If it is already installed, then there should be a program in the computer that can start the scanner and get the image of whatever is on the scanner. Look where the scanner programs are at(usually this is a folder on the start menu). Also, there may be a scan button on the scanner itself. Pushing this button will start a scan and send the image to the computer.(the scanner program should start)
    Feb 25, 2010 | HP Office Equipment & Supplies
    Scanner stops partway along path, motor whines
    There is an obstacle in the scanner path, or the scanning head guides got bent (unlikely). There could also be something in the rubber drive belt driving the scanning head gears. Try looking inside with a light and check for scratches on the guide. Unfortunately, to fix the problem you'll have to either send the scanner to maintenance, or to open it yourself (voiding the warranty).
    Oct 30, 2009 | Canon CanoScan LiDE 90 Flatbed Scanner
    Scanner initializing problem
    remove to top cover where the glass is, at the buttom thers a start point, that usualy gets dust on then the scanner doesnt know where its at.
    May 16, 2009 | HP ScanJet 3970 Flatbed Scanner
    52 scanner error
    HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
    HP LASER PRINTERS 2, 2D, 3, 3D
    1. Defective cable laser scanner to dc controller.
    2. Defective laser scanner assembly.
    HP LASER PRINTERS 2P, 2P+, 3P
    1. Bad scanner motor.
    2. bad dc controller.
    HP LASER PRINTERS 3SI, 4SI, 4V
    1. Faulty cable assembly.
    2. Scanner motor problem.
    3. Defective laser scanner assembly.
    4. Defective dc controller.
    HP LASER PRINTERS 4, 4+, 5
    1. Faulty laser scanner cable.
    HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
    1. Temporary error. Scanner startup failure.
    2. Improperly fitted scanning assembly.
    3. Scanner cable problem.
    4. Defective laser scanner assembly.
    5. Defective dc controller board.
    HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
    1. Temporary error. scanner rotation error.
    2. Replace contact image sensor.
    4. Replace laser scanner.
    5. Replace cables to laser scanner and engine board
    HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
    1. Scanner start up error
    2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
    3. Replace scanner ***'y.
    4. Replace the engine board.
    5. Replace the D.C. controller only on the 8000.
    HP LASER PRINTER 2300 ERROR 52.X
    1. A temporary scanner start up error.
    2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
    3. Replace the scanner ***'y.
    HP LASER PRINTERS 4200, 4300 ERROR 52.XX
    1. Printer scanner speed error has occurred.
    2. Replace laser scanner ***'y
    3. Replace the D.C. controller ***'y
    HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
    1. Error code K - No Black Color.
    2. Error code C - No Cyan Color
    3. Error code M - No Magenta color
    4. Error code Y - No Yellow color
    5. Replace laser scanner ***'y
    6. Replace the D.C. controller ***'y
    HP LASER PRINTERS 5000, 5100
    4. Replace cable ***'y from scanner to D.C. controller.
    HP LASER PRINTERS 8100, 8150
    1.Laser scanner error/start up/rotation error
    2.Replace laser scanner ***'y.
    3.Replace D.C. controller board.
    4.Replace cable ***'y from scanner to D.C. controller
    HP LASER PRINTER 4500, 4550
    1. Temporary error. Laser scanner error/start up/rotation error
    2. Replace laser scanner.
    3. Replace D.C. controller ***'y
    HP COLOR LASER PRINTERS 4600, 5500
    1.Laser scanner error/start up/rotation error.
    2.Take the toners out and reseat them, or replace them
    3. Replace laser scanner ***'y
    4. Replace D.C controller board.
    HP LASER PRINTER 8500, 8550
    2. Replace laser scanner motor.
    HP LASER PRINTER 9000
    1. Temporary laser scanner error/start up/rotation error
    3. Replace upper cable guide assembly.
    4. Replace DC controller.
    Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
    Does not detect
    First of all you have to uninstall your scanner software completely and to restart your computer with the scanner disconnected.
    Reboot
    install the scanner software exactly !!! as hp has recommended.
    Reboot.
    If there#s no success: I started in disassembling the scanner:
    disconnect from power
    solve 2 screws on scanner top
    remove the glass cover
    move the scanner slegde backwards to start position
    assemble the scanner
    power on etc.
    then the same procedure as every ....
    i.e. reinstall your hp scanning software
    hope you hare successfull
    Apr 23, 2008 | HP ScanJet 3200C Flatbed Scanner
    Canon Pixma MP990 InkJet Printer Logo
    16 people viewed this question
    old marine
    old marine
