Question about Intex Pool & Spa
Repair multiple leaks in INTEX Pool bottom
Hi, I need to repair multiple leaks in my INTEX Pool (Bottom). There are to many to do them one at a time, are there any possible suggestions out there? Or maybe a suggestion as to replace only the Plastic?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Intex Master
  • 1,448 Answers
Need more info are you able to drain pool? if so coat with water sealant paint
Posted on Mar 13, 2014
4 Suggested Answers
SOURCE: Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
Posted on May 31, 2010
jharwell668
  • 640 Answers
SOURCE: can u hookup hayward Aquabug to intex above ground
You Aquabug pool cleaner works WITH your pools filter. You much connect the cleaner to your filter system and the filters suction is what powers the cleaner. Since they operate together, you should always run your filter while you are cleaning, but it will never operate in its normal capacity since you are using it for a different purpose. Here is a copy of the users manual if you have any questions about how the cleaner works.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
Posted on Mar 30, 2011
briones93
  • 119 Answers
SOURCE: hi I have ab 18x52'
Get ready for a full weekend of cleaning your pool :) This is the chemical free method...
1st... Start with a clean filter...So clean your filter...
2nd.. Vacuum your pool and get most of the algae up from the bottom and sides.. Go slow so you do not stir up the algae. Make sure you use the vacuum attachment with brushes..
3rd..Clean your filter...
4th...repeat step 2 again...
5th... Clean your filter...
6th... Brush your pool with a pool brush to loosen the remaining algae..
7th... Set your pump timer for 12 hrs and your chlorinator for 10 to 11 of those hrs... and run for 3 days...
8th.. Check your water and see if has cleared and the algae is almost completely gone.. If so, check your free chlorine level and adjust your cycle down if at the required level..
9th.. if your chlorine level is not at optimal, run at the 12 hr cycle for 3 more days and check..
10th.. After water is clear and free of algae, clean your filter and adjust your cycle down to control your free chlorine level...
Good luck and hope this method works for you.. It has for me for over 2 years with my Intex Salt Water system...
Please take the time to rate me and write a comment... really appreciate!!!
Posted on Aug 04, 2011
Air leak ring
patch with pool patch
Aug 11, 2013 | Intex 10' x 30" Easy Set Pool
SMALL HOLE BOTTOM OF 15 x 4 metal frame pool. believe a small pebble caused it. water leaking out is there a way to save the poolwithout draining and taking it apart?
Try this....
You will need;
Pool liner patch kit
Goggles
Body weight to hold you down while doing repair under water.
Most liner repair kits have instructions on wet applications. Cut a piece of the liner kit fabric to cover the entire hole plus at least 1/2" around. You will need to dive in with a mask/goggles to see the hole. Put a thin layer of glue on the patch and spread evenly.. Fold in half on the glue side and go down to the bottom of the pool. Note...The weights will help you stay at the bottom for this part of the repair.. QUICKLY!!! while holding the patch next to the hole. open the patch and place on the hole and push firmly for a few seconds. Come up and place your foot on the patch and hold for 3 minutes or so. Should work...It took me several times to master this technique when I had a hole at the bottom of my pool... Caution!!! You don't need a lot of weight to stay at the bottom. Test from light to heavy until you think you have enough to do the repair..
Good luck and hope this will help you!! If this works for you, please rate!
Jul 19, 2011 | Intex Easy Set Pool 15x36
My 14' pool is leaking from the bottom slowly. 1" per 26hrs. I can not find a hole. No water on the sides of the pool. It is leaking out from under it. How do I find the hole. I have patched holes...
Using goggles I inspect the bottom and looking at each individual speck on the bottom. Sometimes what looks like debris is actually a hole though it seems it would take a good size hole to leak that much. Check the seam by gently trying to spread it.
Jun 14, 2011 | Intex Easy Set Pool 15x36
My pool is leaking where the sides are joined to the bottom how do i repair this leak
Hi
You don't have much choice in the matter. Either find and repair the leaks using a proper vinyl patch kit with underwater glue ( you can get this at your pool shop) or buy and install a new liner.
Thanks for using Fixya.
May 22, 2011 | Intex "" Metal Frame Pool Set (56998e)...
I have the 18 ft x 48" intex easy set infletable pool and it has been set up for almost 1 month. Until a couple days ago I had no problems. In the morning I noticed the water level was down more than a...
This should be easy ... a foot of water? I would suggest you are leaking out the bottom. do you have a mask and snorkel? Watch the bottom from a floating position ... you might find the hole ... there are underwater patch kits for this very purpose.
Aug 24, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Leaky pump
There are rubber gaskets inside that get old and need to be replaced. Thats probably why it's leaking........Thank You For Using FixYa.Com! : )
Jun 17, 2009 | Intex Easy Set 2500 Gph Filter Swimming...
Water loss in pool, but no hole in liner
The only problem is that ther is a leak in the liner. Generally at the bottom where a rock or debris has made a small hole. They can be patched but the pool will need to be drained. Call your local pool service company.
Kurt
Mar 23, 2009 | Intex Frame Set 12 ft x 30 in Pool with...
Pool & Spa Logo
60 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
