Question about Sansui Televison & Video
Sansui DVD 213 outputs - Sansui Televison & Video
Our sansui sv1418 tv is not picking up the video pic or sound from the e360 dvd/cd player i have just bought...really i followed instructions to the T is there something i might be missing?
The player may have been connected incorrectly. The color codes of the player output leads do not necessarily match the inputs on the rear of your TV. Also, you may not be selecting the player as the source of input.
Nov 14, 2016 | Sansui Televison & Video
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Mar 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
I have a 2003 Sansui VRDVD4005 recorder. It currently playsback on channel 4 on my TV and I need to reset it so it plays back on channel 3. Do you know how I can make the change? All suggestions on the...
Turn off the unit. press and hold the "3" button on the remote until you see "rf 3" in the display on the VRDVD4005. This will change the output channel to 3.
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Hooking up external speakers to Sansui HDLCDVD320
I'm sorry, but the Sansui HDLCDVD320 has no analog audio out jacks. If you have a cable or sat box, etc, you might be able to get audio from their outputs. I hope this helps you.
Dec 14, 2008 | Sansui HDLCDVD320 TV/DVD Combo
Sansui 26 HDLCD DVD Audio DVI/HDMI
Does Sansui HDLCD 19WB have a HDMI outlet
Oct 18, 2008 | Sansui HDLCD-2600 26 in. LCD Television
NO SOUND FROM DVD
Try different sound settings in the dvd menu.
Oct 15, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
Sorry.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Televison & Video Logo
16 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
