Question about Car Audio & Video
Sauna CD PC3681 Player will not turn on
This is meant to be installed in a sauna.
SOURCE: I just bought a house with an amerec sauna. The
the 'easy' answer would be a tripped high-limit switch. Inside the generator box, there is a resettable circuit breaker to the heating element, on the top of the water tank.
kill the power to the unit, take off the shell and look for the pushbutton.
If that is the problem, there is a likely chance that the temp sensor in the shower is not working so it overheats and trips the high temp limit.
Posted on Apr 29, 2010
  • 17 Answers
SOURCE: need conair facial sauna steamer
Here it is on the Conair website:
http://www.conair.com/instruction_booklets/MDF2_ib.pdf
Posted on Mar 06, 2011
SOURCE: We have a keys backyard sauna and when you turn it...
I had the same problem,I bought a used one and during assembly thought it didn't matter where I plugged the cables at the top power board, but it does or else once you try to turn on the heat the sauna shuts down.
INSTRUCTIONS: I fixed mine by connecting the cable that runs from the interior light to the last port, then comes a sealed port, then on the next port connect one of the two cables (the largest one) that comes from the temperature controller from the front wall, the rest cables don't matter which port you put them.
Good luck I hope it works, theres little information out there about fixing this problems. the manual doesnt say the order to connect the cables and to top it off the manufacturer went bankrupt.
Posted on Jul 30, 2011
  • 97 Answers
SOURCE: What is the difference between a sauna and a
Saunas can reach different levels of humidity, and accordingly, they are set at different temperatures.
A traditional sauna is between 70 and 100 degrees Celsius, while a Turkish bath, in order to approach the wanted 100% humidity, has a temperature of around 40 degrees to compensate the steam.
Posted on Oct 03, 2013
hina_urgetec
  • 45 Answers
SOURCE: What is a sauna?
Whether it be the traditional Finnish sauna bath, the more modern infrared sauna, a Russian banya, Native American sweat lodge or Roman steam baths, they have been a refuge not only for relaxation, revitalization and social gatherings but also for a wide range of health benefits.
Read more: Saunas
Posted on Dec 20, 2013
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
Tip
Sauna Heater
Oil and Gas Sauna Heaters
Oil and gas heaters are the least popular heaters used in saunas.
One reason is because they're relatively inefficient compared to the others.
Some people even complain about the odor associated with the burning fuel. If they're properly vented, oil and gas heaters should have little or no unpleasant smell
Electric Sauna Heaters
Electric heaters are the most popular used in saunas.
They're easy to control with user friendly touch pads that include a timer and thermostat, and light switch,
They're also efficient and cost just pocket change to operate.
Electric heaters have controls that include a timer, thermostat, and light switch.
Wood Burning Sauna Heaters
If you have a house in the country or easy access to fire wood, a wood burning heater is a great choice for a sauna.
A wood heater may also be a good choice if you have an outdoor sauna.
Wood burning heaters don
on Jan 08, 2011 | Heating & Cooling
Sauna wont get hot enough
When I'm in a traditional sauna like this, I expect the temperature to be between 70 and 90C so that's what I assume you are trying to reach. There could be several reasons for this so make sure each point is checked:
1. Stating the obvious, to increase the temperature inside the sauna, you'll have to ladle water onto the hot sauna stones.
2. Maybe the insulation within your sauna isn't good enough and heat is escaping.
3. Your sauna room could be too big for this heater to heat properly.
4. Maybe the element on the heater isn't performing properly and needs to be replaced.
These were some pointers which Di Vapor gave as possible reasons for lack of heat.
Sauna Electric Heaters Spares
Feb 15, 2014 | Amerec 4.5KW Heater w/ Built-in Dial...
What is a sauna?
"A sauna is a small room or house designed as a place to experience dry or wet heat sessions, or an establishment with one or more of these and auxiliary facilities.
A sauna session can be a social affair in which the participants disrobe and sit or recline in temperatures typically between 70 degrees C (158 degrees F) and 100 degrees C (212 degrees F). This induces relaxation and promotes sweating.
Saunas can be divided into two basic styles: conventional saunas that warm the air or infrared saunas that warm objects. Infrared saunas may use various materials in their heating area such as charcoal, active carbon fibers, and other materials."
Oct 03, 2013 | Pool & Spa
What is the best Sauna I can buy on line?
You can read this article and see how to choose the best sauna: http://www.articleclick.com/Article/What-is-The-Best-Sauna-Who-Makes-The-Best-infrared-Sauna-/1180839
Jan 28, 2013 | Pool & Spa
My viking sauna will not get hot.
I don't know what a sauna has to do with sewing machines... but I suggest that you locate and test the heating element.
Dec 19, 2012 | Sewing Machines
I wont a customer care number for using a sauna belt
d98f4de4-c124-4af1-a8d7-85c53784686e.jpg , buy sauna belt in pune, where to buy sauna belt in india, where to buy sauna belt in mumbai, where to buy sauna slim belt, best sauna belt in india, best sauna slim belt india, buy sauna belt for weight loss, buy sauna belt in chennai, buy sauna belt india, buy sauna belt online india, buy sauna slim belt india, buy sauna slim belt online, buy sauna slim belt online india, buy sauna solution belt, buy slim sauna belt, cost of sauna belt in india, from where to buy sauna belt, how to buy sauna belt, how to buy sauna slim belt, infrared sauna belt india, original sauna belt india, price of sauna belt in india, price of sauna slim belt in india, sauna belt best buy, sauna belt buy, sauna belt buy bangalore, sauna belt buy india, sauna belt buy online, sauna belt cost in india, sauna belt ebay india, sauna belt in india, sauna belt india, sauna belt india price, sauna belt india review, sauna belt india.com, sauna belt indiatimes, sauna belt online shopping india, sauna belt price in india, sauna belt review in india, sauna belt review india, sauna slim belt india, sauna slim belt india price, sauna slim belt price in india, sauna slim belt review india, sauna slim belt suppliers in india, slim sauna belt buy, slim sauna belt price in india, telemall sauna belt india, telemall slim sauna belt india, teleshopping sauna belt india, tvs sauna belt india, velform sauna belt price in india, vibrating sauna belt india, where can i buy a sauna belt, where can i buy sauna slim belt in bangalore, where i can buy sauna belt, where to buy sauna belt, where to buy sauna belt in bangalore, where to buy sauna belt in chennai, where to buy sauna belt in india, where to buy sauna slim belt in chennai, where to buy velform sauna belt
May 16, 2012 | Cell Phones
I have problems with the power of mij sauna. were
Did you get an answer to your question. I am also looking for s126smd3 to buy.
Mar 11, 2011 | RTO 1 Person Ceramic Heater Far Infrared...
Ive got a nordic sauna with a 13 amp plug, but
Unless you have "Nordic Mini 3" for 240 V, all other types of Nordic sauna are more than 5000 Watt which means that their rated current for 240V is more than 30 A. For 120V it is two times more.
I don't know your type of Nordic, the rating of the fuse and what voltage are you using, but it may be less than the needed rating. Check the rated voltage and current of your sauna heater.
If your voltage is equal to the rated and the rated current of the sauna heater is less than the rating of the blown fuse, you may have short in a part of the heater.
Jul 20, 2010 | Mr Sauna Time & Temperature Control,...
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
