Question about MSI L1350D-1672US Netbook
Charging battery Where is battery charge status on L1350d
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
Garmin nuvi 2555lm battery want charge
A common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
While you could have a bad battery, the Nuvi 25xx series is not that old and the date code on the battery is probably from 2010 or later.
If you plug in the charger, the green battery status indicator should go away or you should see a lightning bolt appear over the battery status indicator . If you don't see a change to the battery status indicator when you plug in the charger, then this confirms that the rear USB port is broken and not applying a charge to the battery.
More information can be found here:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
Mar 25, 2013 | Garmin nuvi GPS
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
May 25, 2012 | Dell Inspiron Mini 10v Netbook Computer
How long does it take to charge a new garmin660?
If the battery is in good condition, just a couple hours. Plug the charger into the unit and you should see a yellow lightning bolt over the battery status indicator. 4 green bars means the battery is charged. Anything less and it is not.
To leave the unit in charge, press the on/off power button until the screen says battery charging. You can check the charging status by just touching the screen. If it says battery charge complete, then you are done.
More info here:
- Jim
Aug 26, 2011 | Garmin Nuvi 660 GPS Receiver
No battery status in the screen of Garmin 255. I just bought a new Garmin 255, before charging, it can not on, meaning, the battrey is empty, that is fine. Pluging the car charger, the unit can turn...
The battery status only shows up when the satnav is disconnected from the charger. Your first charge should be a continuous charge until the battery is full. This can be done by connecting it to your computer for 8 hours approximately or 4 hours to your car cigarette lighter socket or 4 hours to an, optional extra, mains charger.
May 20, 2011 | Garmin Nuvi 255 GPS Receiver
I noticed that my charging status of my M-2623u laptop shows a "Plugged in, not charging" status. I turned off the system, took out the battery, waited 5 minutes, reinstalled the battery, and...
Similar topic on answers.microsoft.com below, may it would hlep:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Apr 25, 2011 | Gateway M2623u Laptop Charger...
No battery status Garmin 760
Went to Best Buy and they didn't know how to get the bar up either but said that the unit should be charged in 3 to 4 hours. So, when i unplugged the unit from the wall...the battery status showed up. I guess it doesn't show when the unit is plugged into the AC charger. Now, all is well.
Jan 17, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Power indicatoror
From the manual:
"Attach the barrel tip of the AC Charging Adapter to the AC Charging port of the POWER TO GO® and plug the standard two-prong plug into an appropriate, functioning 120 volt AC outlet. The red Battery Status LED indicator will flash, indicating a proper connection has been made and the unit is charging. The green Battery Status LED indicators will gradually light as the charge level rises. The POWER TO GO® must be charged for approximately 11-17 hours prior to first use. All Battery Status LED indicators will be lit solid (the red indicator will stop flashing) when the unit is fully charged.
Aug 29, 2008 | Black & Decker Power To Go Cordless AC/USB...
MSI L1350D-1672US Netbook Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
