Question about Bower Cameras
Vr unit not working - Bower Cameras
I HAVE A MAGNAVOX DVD PLAYER HOW CAN I OVERIDE THE +VR MODE
Please give us something to work with. What problems are you experiencing? Is this a stand-alone unit or one that connects to a pc? Not sure what your wanting to do..... what does " OVERIDING THE +VR MODE do? "
May 17, 2014 | Computers & Internet
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 27, 2012 | Exercise & Fitness
GO Video VR 3845 DVD/VCR combo will not turn on.
Yes,if u want to.Unplug,replug the unit back after about an hour or so.The unit should reset it self out of protection mode and work again,if nothing in the circuit boards are burn.
Jun 15, 2010 | GoVideo Go Video DVD/VCR Combo
Kenwwod VR-615 - display disappears
Its becuase it is dirty inside, Unplug it. Take the case off of it. Get sum compressed air from a computer store or Walmart. Like 10 dollars. And just blow the whole thing out with that canned air. do it ever 3 months.. It should fix the problem for life!(:
Jan 30, 2010 | Kenwood VR615 Receiver
Vibration Reduction not working
This feature is not an "end-all" to using a tripod for those razor sharp images. The VR may buy you one or two stops of light max. This may be enough in a pinch but invest in a tripod (a good one) for razor sharpness!
Oct 06, 2008 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Receiver standby light,no power
WOOHOO!! I fixed this issue... same problem as everyone else has mentioned... to reset the Kenwood VR-606 receiver, unplug the unit. Hold the power button down and while holding the power button plug the unit in.
Say a prayer...
Then press the power button.
My display isn't working, but my speakers are working, and that's really all I care about right now... good luck to others!
Jan 18, 2008 | Kenwood VR-606 Receiver
Kenwood VR-207 Receiver
You will first need to check the remote control for the unit. Point the remote at a video camera and see if you see the remote light up. If it does try first to UNPLUG the unit for at least a couple of hours. If that as well does not work, you will need to have the unit serviced, as it may have a bad remote sensor on the front board or the microprocessor is No good. Depending on how old this unit is, it may not be worth repairing. Good Luck
Mar 21, 2007 | Kenwood VR-207 Receiver
Cameras Logo
Top Bower Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Are you a Bower Camera Expert? Answer questions, earn points and help others
