Question about HEWLETT-PACKARD G72-B60US NOTEBOOK PC
Hard disk 1-run in test failed on short DTS
BootMSG MISSING ' START UP ' CANT ACESS F8 safemode, can't acess f11 ' and so on.... Hard disk test failed too'
2 Suggested Answers
  • 343 Answers
SOURCE: Windows Boot Manager message: Windows encountered
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
Posted on Jul 23, 2011
I have hp v165w flash drive driver but cant install it say acess denied.
Copy the driver file to hard disk. Run as Administrator.
May 09, 2014 | Computers & Internet
I have a inspiron i1011-26600bk and its telling me a message that says Loading PBR for descriptor 2...done. What should I do?
"Loading PBR for descriptor 2 ... failed" would be the exact error message if the MBR is unable to load the partition boot record for the second partition. There may be more, but here are three possible causes:
1) the partition table is corrupted so that the descriptor points to the wrong place (i.e., says the partition is one place when it's really somewhere else);
2) the partition table descriptor points to the right place, but the boot record there is corrupted or has been erased;
3) The hard disk is failing and having trouble reading the sector with the boot record.
To check (1), visit www.goodells.net/dellrestore/fixes.htm and download the dsrfix utility. In short, if dsrfix reports a clean bill of health, then (1) isn't the problem.
To check (3), run hard disk diagnostic tests. Press F12 when the machine is starting and see if the bios boot menu offers you a hard disk diagnostic test that you can run. Or even better, if you know the brand of the hard disk, most manufacturers should have a free diagnostic utility you can download to test the hard disk.
If it's not (1) or (3), then use Ctrl+F11 to run the Dell restore utility to recreate the Windows partition.
Mar 12, 2011 | Computers & Internet
Need to acess the bios to reset the comp to factory out of the box condition, did it before cant' remember how
Try Alt and F10 as it boots up. If not then you need to go into Safemode (F8) In the advanced options there under system restore there should be the option to restore the factory default installation.This will delete your data; backup any necessary files first.
Feb 19, 2010 | Toshiba Satellite A200-0ET00X Notebook
A/c won't shut off have to use breaker
sounds like your run capacitor has failed you can find it if you remove the top cover there is a side acess were there is a lot of wires coming out remove that acess there should be 3 capacitors 1 fan 1 start 1 run make sure to turn the braker off before checking the capicitors remove the run capicitor & check for shorts
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
CAnt acces safemode from dynex keyboard
Hey,
  1. Restart your computer.
  2. Keep pressing F8.
  3. You get various options.
  4. One of them is safe mode.
Thanks
Apr 15, 2009 | Computers & Internet
Can;t reboot it says lost bootmsg file
recovery disk will not work in this case. wat u need to do is to repair ur operating system. plz try repairing ur operating system with a bootable cd because the missing file is a system file that supports the operating system. hope this solves your problem
Mar 31, 2009 | Computers & Internet
Windows will not start/run.
Try tapping the F8 key while starting up the computer to see if it will start in safemode. If the computer will not start in safemode you may have a failed hard drive that needs to be replaced. If you do get the computer to start in safemode backup all your data and then perform a CHKDSK (check disk) on your hard drive by right clicking on your c drive and going properties and then to tools then checkdisk.
Feb 16, 2009 | Dell Inspiron 2200 Notebook
Can't acess hard disk and security options
You need to Login As an Adminstrator then change the sercurity settings
Oct 07, 2008 | Hitachi TravelStar 80GN 80 GB Hard Drive
Cannot acess hard disk partitions?
Hi, I hope you are using Windows XP and you have partitioned the disk properly.
Goto Control Panel> Administrative Tools> Computer Management> Disk Management
Now you should see all the disks and partitions in each disk and partition names of each partition. Right click the parition and you get all options to do.
Note: Be careful not to mess with C:  partition. Try to stay away from it.
Sep 21, 2008 | Microsoft Windows XP Professional With...
HEWLETT-PACKARD G72-B60US NOTEBOOK PC Logo
14 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
