Question about Garden
Carburetor adjustment pro cut hedge trimmer needing a carburettor adjustment how do you do it
3 Suggested Answers
wadembly
  • 513 Answers
SOURCE: I can't adjust the carburettor on a Homelite Hedge Trimmer
it shouldn't be all that special it'seither a small flat tip screw driver or its usually a torques screw either one should be avalible at any hardware store or toolstore
Posted on Jun 08, 2009
SOURCE: what is the proper adjustment for the carburetor
turn both hi and low set screws in on side of carb and then back them both out 1 1/2 turns. This is called the initial adjustment and you can fine tune it from there if needed, but only turn the screws about 1/8 of a turn at a time.
Posted on Nov 27, 2010
Is there a special tool to adjust the Hi Low fuel mixture on a mc culloch t55 hedge trimmer
Anon, you may need a special type screw drive bit. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Lifetime Warranty 2 Cycle Carburetor Adjustment Tool 4 Piece...
carburetor tool
Adjusting weed eater carb without special tool
Carburetor Adjusting Tool eBay
May 25, 2016 | Garden
Wont idle, baulks when given gas
bad gas, dirty gas, water in gas. Dirty or badly gapped spark plug. Dirty or blocked jets in the carburettor.
Aug 15, 2015 | Weedeater Garden
Added throttle and cuts out
remove the muffler and run it if runs good open the muffler and clean the screen
May 21, 2012 | Oregon Scientific Complete Carburetor for...
The machine starts when the primer is full. As soon as the primer has emptied the machine stops.It seems as though no fuel is getting to the carburettor.
That is indeed the case, fuel is not getting to or through the carburetor. Check the fuel line, including the filter in the tank. Then check the carburetor, clean it if necessary, replace the diaphram in the carburetor. The diaphram is also the fuel pump of the carburetor. Be very careful with the small parts including the little spring in the lower end.
Aug 12, 2011 | Ryobi Gas Hedge Trimmer
What is the proper adjustment for the carburetor on my WeedEater Hedge Trimmer?
Nov 26, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Hard starting
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 11, 2009 | Garden
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Jun 08, 2009 | Garden
Poulan Weed Eater GHT220
there are mntwo different size fuel lines which one does the gas filter hook up to?
Oct 17, 2008 | Poulan Ght225 25cc Gas Hedge Trimmer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
