Question about Epson DiscProducer Disc Publishing System PP100 CDDVD Publishing System (MPN C11C672001) Disc Burner
Change dvd writer - Epson DiscProducer Disc Publishing System PP100 CDDVD Publishing System (MPN C11C672001) Disc Burner
Please give address of service center in thane ( Maharastra ) for Repairing of DVD WRITER of my computer
R. J. Enterprises
Engaged in exporting and supplying of DVD writer, domestic DVD writer, commercial DVD writers, external DVD writers, domestic external DVD writers, internal DVD writers and domestic internal DVD writers.Address: 8, Lohana Mahajan Building, T. M. Road, Kharkar Alli, Thane, Maharashtra - 400 601, India
Phone: +(91)-(22)-25379150/25379558
Mobile / Cell Phone: +(91)-9820692328
Website: http://www.indiamart.com/rj-enterprises/dvd-writer-and-hard-disks.html
Jun 21, 2010 | LG Computers & Internet
Dvd writer not working
what is the OS ?maybe it need to an upgrade or ur dvd-ram & os need to a driver...
May 10, 2010 | LG GSA-H55N DVD-RAM Burner
My dvd writer was working perfectly but when i format my wondow now it is playing only cds & when i insert a dvd it is not giving any response & my driver is also showing as cd-rom
When you formated you erased the driver you need to use your dvd writer as a dvd writer and player. If your dvd-rom came with a cd use it to reinstall the driver and program it uses. Otherwise you can search for your driver thru the manufacturer website or go to www.driversguide.com and find it there.
Dec 17, 2009 | LG 16X Internal DVD-ROM, E-IDE / ATAPI/...
My dvd writer not detecting dvds . ihave changed my dvd writer with a second hand writer but the problem is remain same
At your PC menu, left click Setting, Control Panel, and Add Hardware Wizard and get it open to find out if your DVD writer is installed and working properly. Otherwise, follow the instruction to get it installed. Thereafter, reinstall the software driver for the DVD writer. Otherwise, get your software driver download at the Internet, and install it in your PC. Just type at the Search engine blank( Download for software
driver Brand and Model of your DVDR,) and choose
the software driver applicable. Then, go back to your
PC menu, click open your download and have it
installed.
Nov 29, 2009 | Computers & Internet
New dvd writer recognised as old
Hello.
Go to Control Panel.
Locate System.
Locate your Device Manager.
Under your DVD/CD Rom devices, locate the old DVD writer. Select it. Right click and hit Uninstall.
Now scan your computer for new hardware, and install the new DVD writer with the discs it comes with, if any.
Nov 07, 2009 | Computers & Internet
MY HP 840i dvd-rw can read CD but can't read DVD
if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
Jun 29, 2009 | HP Computers & Internet
My dvd writer became dvd rom only, now I am unable to wirte the cd and dvd by using my dvd wirter which I bough 3 months back
in these case your dvd writer became dvd rom due to optical lens problem. some other case dvd can read only cd or became cd rom also due to optical lens problem. change the optical lens or adjust trimmer for laser.
Jun 10, 2009 | Philips LITE-ON 20x DVD RW Drive -...
Change the dvd writer speed
you did not specify the company name of your writer.
you can change the speed of your writer using a tool called Media Code Speed Edit (MCSE) which is able tomake your DVD writer read and writer faster. If youhave LiteOn, Benq, PHILIPS, HP, LG, NEC, newer PIONEER, Cyberhome,Gigabyte, Samsung and Artec DVD writers, you have a good chance to playwith MCSE and speed up your drive.
MediaCodeSpeedEdit allows you to change the write speed for your mediaand to add new media codes to your firmware by renaming an alreadyavailable media code. The new media code name can be entered manuallyor can be imported from the DVD Identifier media code output to be surethat no special characters are lost. This kind of media code renamingwill remove the original media code name from the patched firmware, soit is no longer supported by the firmware.
Real adding of additional media code names would mean to shift andextend all internal media code tables or patching all media codescanner for all supported firmwares, which would be a quite complextask. So don't do it if you don't know what you are doing.
MCSE basically hack or edit the firmware for your DVD writer and thenyou flash the hacked firmware to update your DVD writer to supportfaster read or write speed. If you don't know where to get your DVDwriter's firmware, you can head to Media CodeSpeed Edit forum to get help. Here is the link to download MCSE
http://www.anonym.to/?http://ala42.cdfreaks.com/MCSE/MediaCodeSpeedEdit.zip
please rate the solution if you like..
Feb 03, 2009 | Sony Vinpower Digital SharkCopierHDD to 8...
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
Epson DiscProducer Disc Publishing System PP100 CDDVD Publishing System (MPN C11C672001)  Disc  Burner Logo
163 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
