Question about Poulan WeedEater Hedge Trimmer 25cc Engine
Where are the screws on carburetor for adjusting
Wanting to adjust a pro cut carburettor but where are the screws, I need a picture
2 Suggested Answers
SOURCE: Poulan Weed Eater GHT220
there are mntwo different size fuel lines which one does the gas filter hook up to?
Posted on Aug 08, 2011
When started idles really high what can i adjust
There are quite a few reasons. What motorcycle do you have?
Feb 11, 2016 | Motorcycles
What is making my atv cut out when I throttle?
Sounds like you carburettor adjustments may well be the problem. As a rough guide, the mixture screw should be turned in lightly until it stops and then backed out 1.5 turns. One other thing you can check is that the main jet in the carb isn't blocked. Check the slot that the main jet needle is on in the old carb. There is usually 3 or 4 slots. The final thing is the fuel level in the float bowl. You would need a manual to know that.
Google
make, model forums
for specialist advice.
Dec 09, 2015 | Garden
The carburettor how to adjust the air and fuel mixture on the carburettor
Find the adjustment screws on the front of the carburetor. Then Start the engine and let it warm to normal operating.
Adjust both screws equally and find the right mixture.Bring both screws up slowly and listen until the engine purrs smoothly. Any raggedness or rattling is a sign of too lean a mixture. Keep turning until you find the sweet spot.
Sep 21, 2015 | Troy bilt Super Bronco Tiller 208cc
Air screw adjustment
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.basic carburettor adjustment tuning 4 stroke and how it works
Two Stroke Scooter ATV Carburetor Settings And Adjustments 2of4 Idle Speed...
Scooter Carburetor Idle Adjust
Scooter Moped Carburetor Adjustment
50cc GET Carburetor Basic Tuning
Dec 07, 2013 | Bajaj Motorcycles
Proper air fuel mixture screw setting
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.Scooter Air Fuel Mixture Screw Adjustment
how to adjust 139qmb gy6 carburetor mixture
May 03, 2013 | Bajaj Motorcycles
I have a 450, and I would like to increase my bar oil output. Where is the adjustment screw? Please!
There is no adjuster for the Husqvarna 450. Husqvarna recommend that if there's not enough oil reaching the bar that you slow down the engine by adjusting the carburettor screw. I have the same saw and also wanted to adjust the oil flow. I didn't change the carburettor and it's still cutting away without doing any damage. It's meant to use less than a tank full of oil to the tank full of fuel when you're cutting near constantly. With stops in between it will use more fuel and less oil.
Nov 08, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a poulan 2150 chainsaw and the chain never stops spinning. how do i adjust it to stop spinning when i am not cutting?
Firstly consult your manual regarding carburettor settings. There should be a high and low speed adjustment on the saw, often called or labeled as "L" and "H".
These are often located on the main motor body, closer to the handle on one side and require a screwdriver or similar to adjust. They might be buried and you have to look down the adjustment holes in the outer body to see the screws.
Basically you need to adjust the "L" or low idle screw.
Firstly, warm up the chainsaw and allow it to get up to temperature... The blade, as you say will probably be spinning still with hands off the throttle... Grab your screwdriver and adjust the "L" or low idle screw turning it counter-clockwise (at least on most saws) very slowly until the chain just stops turning on the bar. If you go to far you may stall the motor. You just want the chain to have just stopped moving on the bar, and that is your "L" setting position...
Has to be done with a warm engine though.
Please rate this solution on FixYa!
Thanks.
Mar 31, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
29 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
