Question about Printronix P7220 Matrix Printer
Weld not detect
Whay..comment print "WELD NOT DETECT" sound "***..titi..***" and tombol power "tip..tip..tip" we pust "pwr" and OK.... but we Bootable print upgrade..
    New Friend:
    Problem Solver:
  • 6 Answers
Hi
The cartridge weld was not detected.
1.Clear the fault message.
2.If message persists, replace the cartridge.
3.If necessary, replace the weld sensor.
Posted on Nov 20, 2014
Why does the wire weld when I touch the metal?
BE CAREFUL. That sucker is hot and you have current going through it! If you get a voltmeter you will detect the juice.
Aug 31, 2015 | Welding Tools
Welder won't speed up to weld ?
What doesnt speed up to weld? the feeder? is the wire burning back? are you getting any wire? this is gmaw / wire right? sounds like it may be running slow
Jul 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Weld detect error
Ribbon weld needs to be replaced.
Jul 01, 2014 | Printronix P7010 Printer
Weld not detect
ykoymgiccohoideraqepirij0rebaq8hginreqebdyeyideraqepiru8docagicai54jwymwicaglcqwrizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8xp8pkfngr0qq4oeaaaaasuvork5cyii=
Like the problem is not by the user fix it. Check the ribbon, check visually all about it is good.
Jun 25, 2014 | Printronix P7220 Matrix Printer
WELD NOT FOUND ERROR
Sounds like a failing weld sensor. Clean it first its on the left side, you can see it when the ribbon is out. If that doesn't help replace it.
May 08, 2013 | Printronix LineJetĀ® P7010 Matrix Printer
After completing a plug weld on sheet metal the molten weld grows to a point as it cools
This is a gas issue. Either you're running out of gas, or there's junk built up in the tip of the gun, keeping the gas from flowing freely. Also, if your arc length is too short, this can happen but it sounds like a gas problem. If the gas isn't an issue, try backing off a little when you make a weld, or turn your wire speed down a hair.
Jul 09, 2011 | Miller matic 140 Mig Weld Package...
Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
May 09, 2010 | Hobart Handler 140 Mig Welder
Bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Dec 18, 2008 | Welding Tools
Error e5 showing
Step 1 : Push Power switch by continue (Tekan Power On/Off)
Step 2 : inserrt plug(Masukan Power, Power Tetap di Tekan)
step 3 : Tekan Tombol Reset 1x, lepaskan Tombol Pwr, Tekan Reset dua kali lagi Sampai Menjadi 0 (tekan tombol tanpa jeda)
Step 4 : Push + display change from 0 to 1 (tekan tombol + untuk merubah 0 ke 1)
Step 5 : Push Power switch again , Printer will be print 1 page(tekan tombol power –> tombol start sampai ngeprint 1 hal.)
step 6 : Open cover (buka tutup printer)
Step 7 : Unplug (cabut kabel power)
Step 8 : Take out ink 40 and 41(lepaskan catridge 40 dan 41)
Step 9 : Insert plug again (pasang kabel power)
Step 10 : Push power switch (tekan tombol power)
Step 11 : Open cover (scan cover) (buka tutup scaner)
Step 12 : Inksert ink 40 , 41 again (masukan catridge 40 dan 41)
Dec 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printronix P7220 Matrix Printer Logo
268 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Chinmay Joshi
Chinmay Joshi
Cliff
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
