Question about Alienware PC Systems Computers & Internet
I managed to turn off the backlight on the keyboard by pressing a function key by mistake, how do I turn the light back on?
  • Janis
    Janis Feb 15, 2014
    Hi emeraldseadi , I want to help you with your problem, but I need more information from you. Did you try pressing the same key combination?
    Is it Fn+Alien FX key?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
There should be a function key to dim and brighten it.
Posted on Mar 09, 2015
4 Suggested Answers
  • 749 Answers
SOURCE: Function keyboard turned on advent QT5500
Hi
Try this my friend,
Press F12, Num Lock, and FN at the same time.
OR F12 and Num Lock/ Scroll Key.
OR Hold the Ctrl and Fn key down together and press also
the Ins(Num LK) key.
Post me whatever the result is... so we could Fixya the problem.
Posted on Feb 03, 2008
  • 240 Answers
SOURCE: ASUS 901XP. Keyboard. Right arrow does not function correctly
Perhaps you can check your manual. Many notebook keys do not function as expected. If you do not have the manual, you may download one here:
http://www.asus.com/product.aspx?P_ID=1sRO7tW9B0OdR9yz
Posted on Nov 27, 2009
  • 31 Answers
SOURCE: I have Asus G73SW and
I recommend reinstalling Windows using the original recovery media from Asus. That should have all of the original drivers and software needed. You can alway upgrade to Windows 7 ultimate after that.
Posted on Mar 26, 2011
"how to turn on keyboard backlight for Acer Aspire"...
To turn on the back lit keyboard, please press and hold the Function (or the Fn key) and then press F9. That should toggle your backlit keyboard on and off.
Jun 15, 2013 | Computers & Internet
Dimming backlight on ec-ws115
Yes. Look for a setting related to the Fn key on the lower left corner of your keyboard, and a similar key on the top row of Function Keys, on which there will be an alternate text in the same color as the Fn key at the bottom.
They are keyed that way so that you must press down on the Fn key first, then the Function Key on the top row which has the text to compliment the action you want to take. Together, they will help you to increase, or decrease the back lighting on the laptop.
Probably there are two separate keys, one to dim it and one to brighten it.
Either of both require you using the Fn key at the lower left of the keyboard.
cheers!
-a.
Apr 20, 2012 | Computers & Internet
The back light is out, how to turn it on?
1.Check your monitor brightness setting. Occasionally, the monitor brightness can get accidentally turned all the way down. This will result in a completely dark laptop screen that appears to lack a backlight. Adjust the monitor brightness via the dedicated brightness keys at the very top of your laptop's keyboard.
2.Toggle the backlight back on via the keyboard. This is accomplished by using the "Function" key, which lies near the bottom left of your laptop keyboard and is marked "Fn." When pressed in conjunction with one of the "Fx" keys on the top row of your keyboard, you can toggle the backlight on and off automatically. There is an "F1" key, an "F2", and so on. The exact key to press simultaneously with your "Fn" key will vary by laptop model, so consult your computer's user manual. You may have accidentally toggled the backlight off and simply need to toggle it back on via this key function.
3.Prepare to operate on your laptop if you cannot toggle the backlight back on. Shut down the laptop. Disconnect the AC adapter cord from the back of the computer, then close the display and turn over the computer.
4.Remove the battery. The battery on most computers is at the top of the laptop's underside, although some computers may feature the battery in a bottom corner. The horizontal outline of the battery will be clearly visible all the same. Beside or just beneath the battery will be a battery-release latch. Slide this to disengage the battery.
5.Turn the laptop back over. Open the display.
6.Observe the bezel, which is the perimeter that runs around the display. There will be a number of rubber caps that exist on the bezel. The exact number will vary by laptop model. Use the tip of a flat-head screwdriver to pry under the caps and pop them off.
7.Remove the screws under the laptop bezel's caps with your Phillips screwdriver.
8.Work around the bezel's perimeter with your fingers and pry the bezel completely off.
9.Look at the bottom of the monitor assembly. A thin inverter board will span horizontally across the screen's bottom. There is a connector on either end of the inverter board. If the right cable is loose from the right connector, lift up on the connector and slide the cable back in. This will restore the laptop's backlight.
10.Replace the bezel and the bezel's screws. Reinsert the battery and power on the laptop.
Sep 12, 2011 | Computers & Internet
How brighten the screen?
Look on your keyboard on the "f" keys (f1, f2, etc...) for a symbol that looks like a sun or shining light. Something that would indicate brightness. Now, hold down the 'fn' (function) key on the bottom left of your keyboard and then press the backlight key you just found.
Mar 01, 2011 | Gateway MX6214 Notebook
How do i turn my kepboard light on?
Set the brightness of the backlighting
1. In the device options, click Screen/Keyboard.
2. Set the Backlight Brightness field.
3. Press the Menu key.
4. Click Save.
Set how long backlighting remains on
2. Set the Backlight Timeout field.
4. Click Save.
Stop backlighting from dimming automatically
2. Change the Automatically Dim Backlight field to Off.
4. Click Save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | RIM BlackBerry Pearl 8100
Instead of getting the @ symbol when I press shift +2 i get "
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail account.....no issue in Word docs.
Jan 13, 2010 | HP D8597A Keyboard
Back light on BlackBerry 8800 keyboard
From the Settings/ Options and Screen/Keyboard there is a backlight timout option where you can change the settings.
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Keyboard is off?
If it's a PS/2 keyboard (round connector, about the diameter of a pencil, check to see if you're plugging it into the keyboard port. It's easy to plug it into the mouse port by mistake.
Another thing to try is to turn off the PC, plug the keyboard in, and turn back on so it will initialize on bootup.
If it's USB, it should be recognized immediately if the keyboard is functional.
Feb 06, 2009 | Acer Aspireā„¢ T180 PC Desktop
My cf30 rubberized keyboard functions but will not backlight. Is it malfunctioning or is there an option somewhere to activate it/turn it on?
There is a function key combination that turns on the back light, I believe it is Fn+F12. Hod down the FN key and press F12. The first press turns the backlight on full brightness and succesive presses dim it until it is turned off.
I'm sorry but I don't have my CF-30 in fromt of me at this time, it could be Fn+F10. There is a blue symbol on the correct key and I believe it looks like a light bulb.
If this doesn't work, you may need to have a hotkey driver installed.
Nov 26, 2008 | Panasonic CF30 Notebook
Keyboard stuck in upper case
Is the caps lock light illuminated? If so, you might have to hold shift and hit caps lock to turn off the caps lock. This is an option for old typists who came from manual typewriters that you might have turned on by mistake.
Mar 05, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
70 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Martin Murray
Larry Chandler
Jerry
Jerry
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
