Question about Pioneer Televison & Video
Pioneer trouble shooting
The power light will not stop flashing
2 Suggested Answers
  • 1694 Answers
SOURCE: Flashing green power light
Verify Model # on back of set ends with....13. If so, then
replace four capacitors in DM module...1000mf 25v 105 degree.
If not,solution will be different....................T.
Posted on Dec 26, 2007
Red light keeps flashing on 50e47-170 how do I fix
The red flash is flashing in a pattern, should be a diagram on the furnace panel that shows trouble shooting codes.... led on means you at least have power...
Feb 20, 2015 | Home Security
Hotpoint aqualtis washing machine model AQXXL 129 PM my doors not locking stopping in a cycle ,and water not draining , and lights flashing
find a dealer and get a manual for the washer it will have a trouble shooting section will tell exactly what is wrong
May 17, 2014 | Washing Machines
Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Feb 21, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
I cant get my pioneer pdp-r05u to stop flashing between tv and stand by
The manufacturer utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to something that may require more attention. They use the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light helps the technician to isolate and diagnose the issue. This in turn speeds up the repair process if repair is needed, helps keep parts costs down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in many cases.
Jun 03, 2011 | Televison & Video
I have a pdp-5041 hd that stopped working- trouble code is 3 flashes on the tv led- any ideas
Look on page 13 of the following link it has a possible cause of failure for the trouble codes - Good Luck
http://www.kallhovde.com/pioneer/tricomp/Audio/Misc/pioneer%20bulletins%20and%20training/Training/FSG_G3_to_5.pdf
thanks,
mc
Oct 28, 2010 | Pioneer Televison & Video
TV does not turn ON and red light keeps flashing six times stops reapeats again with six times red flashing
Sounds like a power supply issue. order a new power supply or trouble-shoot the current. Look for any capacitors that are bulged up on the top and not flat.
Jan 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Gm 5400 pioneer t amp power light blinking nothing coming through sub also amp gets very hot
I had the problem of blinking light when I was first installing the amp. It was my first install, but after trouble shooting, I found my amp was going into safe mode, because of an inconsistent current- my ground connection was not very good. After sanding down the contact areas on the ground, and posotive connection to the battery, the amp worked and sounds very nice. It does get a little hot, keep it well vented.
Jul 11, 2009 | Pioneer Audio Players & Recorders
2 fuses blow on power up
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
