Question about Samsung DV210AEW Sensor Dry Electric Dryer - White
Electrolux sensor dryer error code e66 - Samsung DV210AEW Sensor Dry Electric Dryer - White
I have a code e62 on my dryer
did some research might be a faulty heater or some kind faulty wiring or some kind of circuit board failer. i checked on youtube where i guy talks about errors and he explains them too. Tumble Dryer Error Codes E61 E62 E63 E64 E65 E66 E67 Electrolux AEG Zanussi so try watching this video this help you on what you can do more for your dryer..
Jun 23, 2017 | Computers & Internet
What does error code E60 mean?
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Apr 21, 2016 | Electrolux Washing Machines
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Dado
Feb 21, 2015 | Electrolux Washing Machines
WHAT DOES THE E66 MEAN ON MY AFFINITY DRYER
Good Morning Friend, this is Z, Thank you for your inquiry!
An error code E66 is associated with the heating element relay. A technician would typically check the ohm resistance of the relay to determine if it is the cause of the error code on your Frigidaire dryer. If the readings are incorrect, the heating element is replaced. If the readings are incorrect, it could potentially be the main control board. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
May 21, 2014 | Frigidaire AEQ7000ES Dryer
Electrolux e6 fault code
Good Morning turnmills200 - Could the unit possibly be experiencing an E66 or EB1 and not displaying all of the numbers correct? If so, an error code E66 is associated with the heating element relay. A technician would typically check the ohm resistance of the relay to determine if it is the cause of the error code. If the readings are incorrect, the heating element is replaced. If the readings are incorrect, it could potentially be the main control board. Error code EB1 indicates that the unit has detected an issue with the power frequency of the incoming water that only a power company could verify. If issue persists, then the main control board would possibly need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving. However, if you are not experiencing either of these two error codes, do you have an international model? If so, this could mean something completely different, which I would personally suggest reaching out to the manufacturer directly.
May 22, 2013 | Electrolux Washing Machines
Error code e66
Hello wez1330 - Error code E66 indicates that the thermal limiter circuit is open. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the inlet or outlet thermal limiter for continuity. If the thermal limiter is open, tech will need to check for evidence of high temperature event and any resulting damage. If no futher damage is evident, the thermal limited and retest will need to be replaced.
Sep 29, 2012 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
Mar 08, 2012 | Electrolux EIED55H Dryer
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Samsung DV210AEW Sensor Dry Electric Dryer - White Logo
15 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
