Question about HP OfficeJet Office Equipment & Supplies
Cant print pdf file using hp deskjet d2300
Why is my HP deskjet d2300 wont print pdf file
SOURCE: blinking lights & offline-use printer offline
replace ink cartridge
Posted on May 07, 2008
worldvet
  • 859 Answers
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
Posted on Sep 29, 2008
SOURCE: problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
Posted on Apr 27, 2009
  • 311 Answers
SOURCE: my hp f 380 printer wont print pdf documents
in this case
open pdf
the click on print
now you need to look for the option that says print as image and this option has to be checked
you can get the option by clickon on advanced or prefrences
Thanks
Posted on Mar 05, 2010
  • 401 Answers
SOURCE: hp 2055 cannot print pdf
UNCHECK PRINT TO FILE CHECK BOX
Posted on Mar 09, 2010
I have an HPDeskjet D2360. It prints the test page correctly but if coming from a document such as MS office Open office or PDF, it comes out blank. Tried both for windows 7 and 10. How do i fix this?
If you can print, consult your firewall vendor's support site for steps to add the printer as an exception to allow communication with your printer. The printer uses UDP ports 137, 138, 161, 162, 427, and TCP ports 137, 139, 427, 9100, 9220, and 9500. After changing adding these ports as exceptions, re-enable the firewall in the Print and Scan Doctor.
http://support.hp.com/us-en/product/HP-Deskjet-D2300-Printer-series/1841737/model/1101015/document/c04714314/
could be a printer language mismatch with driver
check services and if print spooler is running
Oct 26, 2016 | Office Equipment & Supplies
HP Deskjet 5110 attached to a Vista laptop wont print PDF documents. When trying to print I get a message to install a printer, but I cant print from every other source OK.
If you are using Adobe Reader, check if your printer is still the default printer if you still have problem printing, then check the printing preferences in Adobe. In the Adobe Print dialog Box clic advanced preference, under postScript Option select "Send for Each Page" for "Font and Ressource Policy"
Jul 27, 2011 | HP DeskJet 5150 InkJet Printer
My hp f 380 printer wont print pdf documents if i use the print option from the pdf files. it makes a noise as if getting ready to print but then doesn't. if i copy the pdf document to word it will happily...
in this case
open pdf
the click on print
Thanks
Mar 05, 2010 | HP DeskJet F380 All-In-One Printer
I have lost the cd of hp deskjet d 2300 i
The link below will take you to the HP support site, where you can download the appropriate drivers based on your operating system
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1100995&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 25, 2009 | HP Deskjet 2360 InkJet Printer
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
How do I get an HP 9800 Deskjet to print dgn/dwg files?
Download and install the FREE Bentlley View program which will allow you to print DGN files.
http://www.bentley.com/en-US/Products/Bentley+View/Product-Overview.htm
Let me know if this resolves your issue.
Thanks for using FixYa!
Apr 07, 2009 | HP DeskJet 9800 InkJet Printer
HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
My deskjet 2460 canĀ“t print excel files
I need a installer driver of my printer HP Deskjet D2460, kindly please help me. Thanks
Mar 13, 2008 | HP Deskjet 2460 InkJet Printer
Printer not working
my hp 2300jet ink printer not taking paper,green light only blinking
Mar 10, 2008 | HP DeskJet 3940 InkJet Photo Printer
19 people viewed this question
Seeker5211
Seeker5211
