Question about Life Fitness Exercise & Fitness
Where is battery located for lifefitness ct-9100
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: how do i reset the waxer on a 9100 lifefitness
Press these buttons:
101–ENTER–
HILL–RANDOM–
FIT TEST.
Program lights come on. Display will scroll toWAX DELAY OFF.
Press speed "UP" or "DOWN"
to toggle to
WAX DELAY ON or OFF.
Posted on May 13, 2010
The Fit Test and Fat Burn do not light up as an option on my Lifecycle 6500HR bike, they used to work now they don't.
This really sounds like there is a problem with your console. You might consider contacting LifeFitness for replacement options and or further troubleshooting. 1-800-351-3737 is the contact phone number for them directly.
Mar 23, 2014 | Life Fitness Nut Lock, Cranknut, Lifecycle...
Tip
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
I want to know what is a control processor and main processor for lifefitness treadmill 9100 and where it is located at. thanks
1_ CPU is SYSCON, is the unit control electronic,that sen all electronical signal to the electronic of equipment.
2) tight every wires connector very well and clean it
3) Run the software calibration for diagnose, troubleshooting , fix it
4) However you must calibrate the REED swith, see the diagram, clean it, and tigh the wires connector very well, exchange the batteries by new ones and clean the contacts cleaner 5) tight the ribbon cables from keypads switch +tight the display board connector vs lower board and proof again.
God bless you
Jul 26, 2012 | Life Fitness 9100 Next Generation...
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
How do i reset the waxer on a 9100 lifefitness treadmill?
101–ENTER–
HILL–RANDOM–
FIT TEST.
to toggle to
May 13, 2010 | Treadmill Doctor LifeFitness 9100...
I have a Lifefitness Treadmill model TR 9100, serial 381872. When I turn on the power switch, the treadmill does nothing. Nothing appears or lights up on the front console. I removed the motor cover and...
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
Jan 02, 2010 | Life Fitness 9100 Next Generation...
Exercise & Fitness Logo
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
