Question about Tag Heuer Indy 500 Mens Chronograph Quartz Watch CAH101C.FT6026
Chronograph not working - Tag Heuer Indy 500 Mens Chronograph Quartz Watch CAH101C.FT6026
Can get the time to start
The watch is a chronograph. If the time hands are not working, minutes and hours, you probably need a new battery. If they are working and it is the chronograph(stopwatch) hands you can't get going then you need to push the buttons that control the chronograph.
Oct 16, 2012 | Nixon The 42-20 Chrono Watch All Black One...
How it works invicta clock mechanism ?
Your watch is battery powered or a 'quartz' watch. It is commonly refered to as a 'chronograph'. That is another word for stop watch.As well as telling time and the date, your watch can time how long an event lasts. For example, a horse race. You start the chronograph or stop watch when the horse starts and stop it when it crosses the finish line. When the next horse starts you need set it back to zero to time the next race.Operation is simple. The upper push button starts and stops the chronograph. Try it. Now with the chronograph stopped, push the bottom button. The hand return to the 12 o'clock position or the 'zero' position. Also notice the small dials on the dial or face of the watch. They record minutes and other increments of time. The large hand going around when you push the upper button is recording seconds. Hope this helps, Michael
Oct 09, 2012 | Invicta Lupah Collection Chronograph #9813...
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
Watch is working fine but the chronograph is not
sounds like it needs to be serviced under warranty. The clutch mechanism maybe jammed or broken.
Apr 26, 2010 | Sector 2653940025 Wrist Watch
Fossil Chronograph--need to know what the two buttons on the side do
Two push buttons is for chronograph function. When you push the upper button - chronograph starts, second push on same button - stops the chronograph. Push on lower button - chronograph resets to zero. Rate me, plz.
Feb 03, 2010 | Watches
HI, i have a gucci watch YA077310 and i dont know how to set it. also the second hand does not work.
To set the time, you normally pull out the crown and rotate it. The main (large) second hand is associated with the chronograph function so is stopped at 12 when no using chronograph. There should be a little second hand in a little round area on dial that is moving.
Jan 26, 2009 | Gucci 7705 Chronograph YA077310 (17736)
Tachometer Chronograph Operation.. HELP?
a Tachometer chronograph is a time and speed measurement.
Jun 28, 2017 | Fossil Metal Chronograph White Dial ES1793...
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Tag Heuer Indy 500 Mens Chronograph Quartz Watch CAH101C.FT6026 Logo
83 people viewed this question
Top Tag Heuer Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Tag Heuer Hardware and Accessory Expert? Answer questions, earn points and help others
