Question about Vision Fitness T9600 Treadmill
E5 error code vision fitness T9600 - Vision Fitness T9600 Treadmill
What does an E5 code mean?
Make and model helps, but here are all the E5 Error Codes we get asked.
On a cellphone?
E5 code Google Search
On a washing machine
e5 error code code washing machines Google Search
Dishwasher
e5 error code code dishwasher Google Search
Stove / Cooker
e5 error code code stoves Google Search
Fridge
samsung fridge e5 error code Google Search
Aug 27, 2017 | Cell Phones
What does error code R5232 Failed mean on Vision Fitness T9600HRT treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 04, 2016 | Vision Fitness Exercise & Fitness
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
How do I fix E5 error on my Vision Fitness T9450 treadmiill
The primary cause of E5 is the elevation system malfunction - Elevation error (signal lost)
First check all wires from the elevation motor to the lower motor control board. Also check the main wiring harness from the console to the lower motor controller to determine if a wire has been cut, pinched or shorted to ground.
If all wiring is in perfect condition and the unit has not been recently moved, dismantled/reassembled, then there might be a failure of the lift motor itself, or in some cases the motor control board (controller)
Nov 26, 2013 | Vision Fitness Exercise & Fitness
My t9600hrt treadmill stopps working after about 15min and then i can start it up again and same
Lube the treadmill for deck belt+roller bearing too.
This happen because the lack of maintenance schedule.
See the video, if after you fix it, the problem remain, is TIME to replace the old deck board.
God bless you
Feb 25, 2013 | Vision Fitness T9600 Deluxe Treadmill
I have a Vision Fitness T9600 and when I start it, it doesn't go any faster than .5 mph. When I push down on the arrow keys, nothing happens. The elevation doesn't repond to the pushing of t
You must measure the 8' 12 vDC Voltage to display from the terminal from Controller board motor.
If there are the Console Board is faulty. However tight very well and cleaned it with electronic spray cleaner.
If there are NOT, the controller board motor is faulty, some IGTBs are faulty. REPLACE
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How to Determine If Treadmill Console Is Broken
Nov 26, 2017 | Exercise & Fitness
No start no stop of my teadmill t9600 but the other buttons areok
these are the most often used functions you just worn them out you can call vision fitness they will ask the upper console model and serial # (located on the back end of the console ) Here is their # 1-800-335-4348
May 13, 2010 | Dmm Vision Fitness T9500 Treadmill
The buttons on this unit are on an overlay. Basically, the buttons are a big sticker that goes on the console. I would start by checking the connection between the overlay and the console board. If the connections in good, then try a new overlay. If that does not work then the console board is bad.
Mar 22, 2010 | Dmm Vision Fitness T9500 Treadmill
Vision Fitness T9600 Treadmill Logo
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
rattack1511
Level 1 Expert
ray gallant
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
