Question about APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS System
Reparing main board mop - APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS System
Can you repair main samsung board BN94-07278B
Generally it's not easy to repar a main board. No way to tell fron a Q&A forum. The only way is to check each one idividually, evaluate the damage and the possibility of repair vs replacing the board or disposign of it as irreparable.
So, take your computers to a repair service and ask for the dignostics,
By the way, looks that your "surge supressor" was not working. Get yourself a good one
Sep 12, 2016 | Samsung Televison & Video
I cannot get any sound on my sylvan flat panel television. Have checked to see if it is on mute and it is not
Can be the main board or the speakers faulty.in most lcd led tvs audio amplifier is integrated in to the main board. so if there is any fault in it then you have to reparable the board. repairing is not possible as its need smd rework station. or you have to contact the authorized servicing center.
If you wish to get some details about any other product and circuits check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Feb 21, 2015 | Sylvania Televison & Video
Will not turn on
Check and reparable its main power regulator [SMPS] board.
Jan 08, 2014 | Televison & Video
Philips plasma is black and white with lines
Main board is likely to be faulty. Contact the authorized service center for Philips. This is not a user reparable fault. So many adjustments are there, after the main board repair/replacement. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 08, 2014 | Philips 50PFP5332D 50 in. Plasma...
Turn on tv and no sound or picture, just a "beeping" sound
The main board to your TV has the fault. Check and replace it. The work is a skilled one, and not a user reparable. Contact any experienced service technician.
Jan 08, 2013 | RCA F36685 36" TV
E51 what does it mean
code e51 on your dryer is a component called a triac on the main board that is at fault not a diy repare
Aug 17, 2012 | Electrolux Dryers
Receiver Powers off after a few seconds
its a problem of main board circuit tracks.the circuit is getting short so it overheats and the unit turns off.
it needs reparing.
Apr 01, 2009 | Audio Players & Recorders
Computer not powering on
There are various reasons a computer may not power on ....... there may b a problem with the power supply , there cud b a problem with the mother board .....
Try
open the cabinet ...... remove the main power cord connected to the mother board wait for a few seconds and connect back ...check
Oct 18, 2008 | Sony Ericsson K800i Cellular Phone
Tv has no picture only sound
on the main power supply board the capacitors are blown or bulged.which supports the picture to display on the screen.replace that capacitors and ICS from the main board.
if donot have any technical knowledge call a technician.it is much advisable.and it is worth reparing.
thanks.
Oct 14, 2008 | Televison & Video
Phillips model 29PT6773/05
if the fuse seems to be ok then on the power supply board check for any blown capacitor or any bulged capacitor or ics.that could also create the problem if blows off.you have to replace the capacitors and ics.to make the tv work again.check out for the fauly on the tracks of the main board.
you can also call a tech as it is worth reparing.
thanks.
Jun 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS System Logo
49 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
