No sound when I connect the hdm2 cable to my TV
The TV works fine but when I connect the cable from my TV to my computer and try to play movies off the internet there is NO sound.
  • 18 Answers
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Posted on Aug 19, 2007
  • 47 Answers
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Posted on Mar 09, 2008
dutchman05
  • 487 Answers
SOURCE: LG LCD/DVD TV no sound on TV - DVD works fine with sound!!!!
HERE is the servce manual for this TV
Posted on Jun 21, 2008
freetek
  • 5568 Answers
SOURCE: No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Posted on Aug 02, 2008
  • 4 Answers
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
The color turns predominately green intermittently
Please try to play any DVD movies to determine if the problem is on the TV or on the cable/aerial connection and reception..
If you play DVD and works fine?
The TV is good but the problem is on the aerial antenna if you are using analog..and if you are using digital cable please double check the connection and cable box..or try to contact your cable provider..
Dec 19, 2011 | Olevia LT32HVE 32 in. LCD Television
Don't have cable. Have the digital converter box and a indoor antenna...it's hooked up and TV is playing fine. After hours of changing every cable the VCR will not play. I get the sound of the movie but no...
You can connect VCR, TV and converter box using coaxial cables OR you can connect using RCA cables. See this web page:
http://columbiaisax.googlepages.com/diagram_dtv_tv_vcr.htm
Using RCA cables, make sure you connect the yellow video cable. Select the proper input on the TV.
Aug 12, 2010 | Televison & Video
No Sound comings from bp 1500
hi i have had this you sometimes get a delay on the sound when you boot up i just changed my hdmi lead and it rectified it try using a 1.3 instead of 1.2 hdmi lead.
Mar 21, 2009 | Samsung BD-P1500 Blu-Ray Player
Proscan tv surround sound hook up
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
Mar 04, 2008 | Panasonic SC-HT680 System
No sound but plays the dvd fine
I think this is due to wrong Audio settings.
Try to change audio setting as Stereo/Right or Left/5.1 from the Audio setup of the Menu
Dec 14, 2007 | Emerson SpongeBob SquarePants 3D Sculpted...
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
No cable picture or sound
only thing I can think of is for you to check your cables... assuming you are using a coaxial cable for the satelite and rca cables for games and dvds, I would recommend trying a different coaxial cable. There is also the chance that the coaxial connection on the tv itself is messed up. you may try buying an RF modulator that will convert coaxial to rca, most rf modulators convert rca to coax. so make sure it does what you need before you buy it. tech guys at store should be able to help if you can't figure it out.
Jun 19, 2007 | Toshiba TP50F60/61 TV
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
