Question about GE Americana A3316ABS Top Freezer Refrigerator
Americana refrigerator drip pan location - GE Americana A3316ABS Top Freezer Refrigerator
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Where is the drip pan located on a samsung refrigerator model num rs265tdrs
Danita,
Drip pans are usually mounted in one of two places. On top of the compressor or underneath the refrigerator box. You can take your grill of the front of your refrigerator below the door opening and look through that opening and see if there is a drip pan there, if not, it should be on top of the compressor. You can find that by taking the cardboard or fiberboard cover off of the back of the unit. Hope this helps!
Jul 06, 2015 | Samsung Refrigerators
Where is the drip pan on Frigidaire 18 cu. Ft. Refrigerator
Hello friend, that's a great question!
Typically the drain pan is located at the bottom of your Frigidaire refrigerator. You can look it by removing the toe grille. Hopefully this is helpful. -Matt
Sep 10, 2014 | Frigidaire Refrigerators
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Where is the drip pan located on this refrigerator
drip pan is usually located on the bottom of the fridgfe somwhere near the compressor
Jul 24, 2010 | Estate TT18SKXRD Top Freezer Refrigerator
Water leaking from under refrigerator
The drip pan is located from behind the refrigerator. You have to take the cardboard off and unplug the unit. You will see the drip pan with the fan unit on top of it.
Apr 29, 2009 | Refrigerators
Leaking refrigerator
  • if the drip pan is not cracked or overflowing then it could be that the drain tube that goes to the pan is clogged.
  •  a good thorough cleaning of the freezer should help.
  • also pour a little hot water in the back of the freezer (i take the refrigerator outside and blast it with a hose, but thats just me), this will hopefully melt any ice buildup that may be causing the problem.
  • the tube sometimes runs on the outside of the refrigerator along the back.
  •  either way the tube goes from the bottom of the freezer to the drip pan.
  •  let me know how if you need more help.
Jul 01, 2008 | GALAXY Microsystems 63702 Top Freezer...
GE Americana A3316ABS Top Freezer Refrigerator Logo
32 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
